    Raspberry pi performance
    5 Posts 6 Posters 2.6k Views 6 Watching
    • N
      Nneuland
      I’ve been modifying my mirror for a little while now, and have my config file pretty cleaned up. But have a question.
      I’ve noticed after a fresh restart of the pi, everything runs very smoothly. Modules update perfectly and on time. The clock modules seconds display is perfectly in time. However, over time, the modules start lagging on their refresh rates. The clock modules “seconds” display - instead of every second, starts updating every other second. And after being on for a full day or two, every 5-10 seconds.
      I only mention the clock module because it is the most noticeable, but other modules are also experiencing similar refresh issues.
      This seems like a fixable issue, but I’m not positive where to being looking.
      Hopefully I’ve described the problem correctly.
      Can anyone offer any suggestions?
      Thank you so much
      Nick
        MMRIZE @Nneuland
        @Nneuland
        Check this; https://raspberrytips.com/time-sync-raspberry-pi/
        • N
          Nneuland @MMRIZE
          @MMRIZE
          Thank you for the response. I only looked at the link quickly, but I’m not sure that its the issue. Unless I am misunderstanding syncing time as described.
          My issue is more about the pi taking incrementally longer to refresh each module, I only mention the clock module because the seconds display is the most noticeable. Still very much open to any thoughts or suggestions
          • uros76U
            uros76
            Which rPi are you using?
            • N
              Nneuland @uros76
              @uros76
              Pi4
