    PIR Sensor doesnt detect movement
    10 Posts 3 Posters 2.4k Views 3 Watching
      1BlauNitrox
      Hey guys,
      I am currently working on my Magic Mirror and want to add an PIR Sensor to it.
      I use the MMM-PIRModule to turn the monitor off and on.
      When I run the program by npm run start the mirror starts but the minotor instantly turns off and never on again. I dont`t know if the sensor is broken or if I just configured something wrong.
      The config looks like this:
      	module: 'MMM-PIR-Sensor',
      		sensorPIN: 14,
      		powerSaving: true,
      		offDelay: 30000,
      If you need more information tell me.
      T 1 Reply Last reply
      • T
        tanvir586 @1BlauNitrox
        @1BlauNitrox try pin 22 and use this configuration.
            			sensorPin: 22,
                                    powerSaving: true,
                                    powerSavingDelay: 30,
        1 1 Reply Last reply
          1BlauNitrox @tanvir586
          @tanvir586 Yeah, I worked. Thank you.
          But there is one issue. When the monitor turns off, there is a blue screen for about 5 seconds…
          How can I fix this?
          • T
            @1BlauNitrox I don’t think you can fix it. Looks like it’s monitor settings. After 30 seconds raspberry cut the hdmi power then your monitor should go to sleep straight away. But it’s delaying 5 ses. Try the monitor settings if you can find a option that goes to sleep straight away.
            S 1 2 Replies Last reply
              sdetweil @tanvir586
              @tanvir586 my monitors (multiple brands) put up the no input panel for 15 minutes (the energystar spec defined timeout)
              not able to change it…
                @tanvir586 I think every monitor has the same behaviour. When you cut the hdmi signal there will be a blue screen “No input signal”.
                • T
                  @1BlauNitrox I used AOC monitor and it doesn’t do it. After hdmi power cut it shows no signal and go to sleep straight away. No blue screen.
                    sdetweil @tanvir586
                    @tanvir586 lucky… pre-energystar
                      @tanvir586 can you send me a link to your monitor?
                      • T
                        @1BlauNitrox it’s 28 inch lcd monitor. Few years old. Don’t know the model
