    Black screen after updating to 2.19
    4 Posts 2 Posters 1.1k Views 2 Watching
      requiemmg
      just updated my MM from 2.18 to 2.19, @sdetweil’s update script threw no errors.
      Now I get a black screen with mouse pointer only.
      pm2 logs --lines=50 output:
      0|MagicMir | [02.04.2022 09:09.59.133] [WARN]  [yahoo-finance2] Please upgrade to yahoo-finance2@latest, i.e. 2.x.  The only breaking change is a fix in quoteSummary to correctly return Date objects instead of numerical timestamps in these submodules: defaultKeyStatistics, earningsHistory, insiderHolders. For more info see: https://github.com/gadicc/node-yahoo-finance2/commit/4cf1f624d55d92f80db4b36b3afe9414f5eb5a3c
      0|MagicMir | [02.04.2022 09:09.59.764] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'request'
      0|MagicMir | Require stack:
      0|MagicMir | - /home/pi/MagicMirror/modules/MMM-MyCommute/node_helper.js
      0|MagicMir | - /home/pi/MagicMirror/js/app.js
      0|MagicMir | - /home/pi/MagicMirror/js/electron.js
      0|MagicMir | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
      0|MagicMir | -
      0|MagicMir | [02.04.2022 09:09.59.774] [ERROR] App threw an error during load
      0|MagicMir | [02.04.2022 09:09.59.780] [ERROR] Error: Cannot find module 'request'
      0|MagicMir | -
      0|MagicMir |     at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
      0|MagicMir |     at Function.n._resolveFilename (node:electron/js2c/browser_init:249:1105)
      0|MagicMir |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
      0|MagicMir |     at Module._load (node:internal/modules/cjs/loader:785:27)
      0|MagicMir |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
      0|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1012:19)
      0|MagicMir |     at require (node:internal/modules/cjs/helpers:102:18)
      0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-MyCommute/node_helper.js:9:17)
      0|MagicMir |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
      0|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
      0|MagicMir | [02.04.2022 09:09.59.783] [ERROR] Whoops! There was an uncaught exception...
      0|MagicMir | [02.04.2022 09:09.59.795] [ERROR] Error: Cannot find module 'request'
      0|MagicMir | -
      0|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10) {
      0|MagicMir |   code: 'MODULE_NOT_FOUND',
      0|MagicMir |   requireStack: [
      0|MagicMir |     '/home/pi/MagicMirror/modules/MMM-MyCommute/node_helper.js',
      0|MagicMir |     '/home/pi/MagicMirror/js/app.js',
      0|MagicMir |     '/home/pi/MagicMirror/js/electron.js',
      0|MagicMir |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
      0|MagicMir |     undefined
      0|MagicMir |   ]
      0|MagicMir | }
      0|MagicMir | [02.04.2022 09:09.59.798] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|MagicMir | [02.04.2022 09:09.59.800] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|MagicMir | [3003:0402/091001.395115:ERROR:viz_main_impl.cc(188)] Exiting GPU process due to errors during initialization
      0|MagicMir | [3030:0402/091001.541186:ERROR:sandbox_linux.cc(377)] InitializeSandbox() called with multiple threads in process gpu-process.
      The pi has a internet connection.
      Any ideas?
        mickecarlsson @requiemmg
        @requiemmg
        Go down to modules/MMM-MyCommute and run:
        npm install request
        restart MM
          requiemmg @mickecarlsson
          @mickecarlsson Thanks, “request” had to be installed there and for another module, now my mirror is working again.
            @requiemmg
            Can you mark this as solved?
