    MMM-ModuleScheduler update
    Scheduled Pinned Locked Moved Forum
    11 Posts 2 Posters 5.3k Views 2 Watching
      Canguingo
      Hi there,
      I have updated to the last version of MagicMirror. besides some issues with the weather module (see my other threats) i get a warning to update the MMM-ModuleScheduler module. it is 19 commits behind.
      What? Does this not update auto?
      any suggestions?
      many thanks in advance!
        sdetweil @Canguingo
        @Canguingo no updates for mm are automatic
        to update a module. go to it’s folder and type
        git pull
        if that is successful, and there is a package.json file, then also do
        npm install
        then restart MagicMirror
          Canguingo @sdetweil
          @sdetweil said in MMM-ModuleScheduler update:
          git pull
          npm install
          Ok! So I type cd mmm-modulescheduler or something like that?
          Sorry I usually follow the instructions very carefully without really knowing what I do.
            sdetweil @Canguingo
            @Canguingo well, modules are loaded into the
            MagicMirror/modules folder
            so your command will work from there
              Canguingo @sdetweil
              thanks this doesnt work
                sdetweil @Canguingo
                @Canguingo what doesn’t?
                linux is case sensitive…
                cd ~/MagicMirror/modules
                cd modulename
                git pull
                npm install
                  Canguingo @sdetweil
                  cd modulename
                  git pull
                  npm install
                  great now i’m 28 commits behind instead of 19 …
                    sdetweil @Canguingo
                    @Canguingo did the git pull succeed?
                      Canguingo @sdetweil
                      Not really,
                      I went to MagicMirror/modules/MMM-ModuleScheduler and there I did the git pull
                      and the npm install.
                      Then back to root and a sudo reboot.
                      But did not help the issue.
                      I might miss something, a step or something… dunno.
                        sdetweil @Canguingo
                        @Canguingo no, I was asking, did the command
                        git pull
                        work.
                        so, go there again and do the git pull and show the results
                          Canguingo @sdetweil
                          git pull
                          work.
                          Thanks Sam.
                          It seems I had to delete some files from the ModuleScheduler before in order to get git pull to work.
                          Now it looks it’s working.
                          Many thanks!
