    MMM-ModuleScheduler update
    Scheduled Pinned Locked Moved Forum
    11 Posts 2 Posters 4.2k Views 2 Watching
      Canguingo @sdetweil
      @sdetweil said in MMM-ModuleScheduler update:
      @Canguingo no updates for mm are automatic
      to update a module. go to it’s folder and type
      git pull
      if that is successful, and there is a package.json file, then also do
      npm install
      then restart MagicMirror
      Ok! So I type cd mmm-modulescheduler or something like that?
      Sorry I usually follow the instructions very carefully without really knowing what I do.
        sdetweil @Canguingo
        @Canguingo well, modules are loaded into the
        MagicMirror/modules folder
        so your command will work from there
          Canguingo @sdetweil
          thanks this doesnt work
            sdetweil @Canguingo
            @Canguingo what doesn’t?
            linux is case sensitive…
            cd ~/MagicMirror/modules
            cd modulename
            git pull
            npm install
              Canguingo @sdetweil
              cd modulename
              git pull
              npm install
              great now i’m 28 commits behind instead of 19 …
                sdetweil @Canguingo
                @Canguingo did the git pull succeed?
                  Canguingo @sdetweil
                  Not really,
                  I went to MagicMirror/modules/MMM-ModuleScheduler and there I did the git pull
                  and the npm install.
                  Then back to root and a sudo reboot.
                  But did not help the issue.
                  I might miss something, a step or something… dunno.
                    sdetweil @Canguingo
                    @Canguingo no, I was asking, did the command
                    git pull
                    work.
                    so, go there again and do the git pull and show the results
                      Canguingo @sdetweil
                      git pull
                      work.
                      Thanks Sam.
                      It seems I had to delete some files from the ModuleScheduler before in order to get git pull to work.
                      Now it looks it’s working.
                      Many thanks!
