    Can't find another module
    6 Posts 4 Posters 1.5k Views 4 Watching
    • F Offline
      Fonfon
      Hi everyone,
      Can you help me to change MMM-PIR-Sensor because i allways have lot of problem with this module.
      I want to find another one with a pirsensor .
      Can you help me ?
      bugsounetB O 2 Replies Last reply Reply Quote 0
      • bugsounetB Offline
        bugsounet Banned @Fonfon
        @Fonfon maybe, if you search better ;)
          mikecheng2626
          Look for Bugsounet’s modules. He has his own forum.
          I’ve recently used his entire modules and extensions/plug-ins. Very satisfied with everything.
          • F Offline
            Fonfon @bugsounet
            @bugsounet said in Can't find another module:
            I find your wiki but my problems with your module is you say : Node >=v14 but <v16
            and i’m in 16.4… and i dont know how to downgrade node.
            Thanks.
            • O Offline
              OliWer @Fonfon
              @Fonfon I’m using MMM-PIR (https://github.com/mboskamp/MMM-PIR) since a couple of days since I was not able to get MMM-PIR-Sensor to work again. You don’t need to display the information of the module at all, so basically you can use it pretty much the same way as the other module.
              Cheers
              Oliver
              bugsounetB 1 Reply Last reply Reply Quote 0
                bugsounet Banned @OliWer
                @OliWer, yes MagicMirror is complex (like your real live !)
