    MMM-PythonPrint customisation
    46 Posts 5 Posters 20.9k Views 5 Watching
      sdetweil @RobCee
      @RobCee said in MMM-PythonPrint customisation:
      ReferenceError: data is not defined
      are u launching ‘python’ or python3?
      the default
      const python=‘python’
        RobCee @sdetweil
        @sdetweil I am using python3 and I have updated the two references to ‘python’ -> ‘python3’ to reflect this
          sdetweil @RobCee
          @RobCee right, you don’t have to change the code, just use the config.js setting
          module:
                   pythonName:'python3',
            RobCee @sdetweil
            @sdetweil ok, I will try it there then and see what happens.
            Tracking down errors in this MM OS is fun…
              sdetweil @RobCee
              @RobCee o, I see that I have a potential bug… if the command: is not configured,
              it defaults to “”… oops…
              I just pushed an update got that
              git pull in the module folder
              to debug
              add debug: true
              and then look where u start MM… (this doing npm start )
              [11.04.2022 10:55.13.087] [LOG]   MMM-PythonPrint received a socket notification: CONFIG - Payload: [object Object]
              [11.04.2022 10:55.13.087] [LOG]   PythonPrint spawning modules/MMM-PythonPrint/printit.py
              [11.04.2022 10:55.18.114] [LOG]   PythonPrint sending program output=hello
                RobCee @sdetweil
                @sdetweil I will have a go with that, but I think I have a slightly different problem of my own making.
                  sdetweil @RobCee
                  @RobCee ok, I also fixed the use of the pythonName and added it to the debug message
                  [11.04.2022 11:04.20.218] [LOG]   PythonPrint spawning modules/MMM-PythonPrint/printit.py using python3
                  [11.04.2022 11:04.25.244] [LOG]   PythonPrint sending program output=hello
                    RobCee
                    I’m not sure why, as I did manage to get it working at one point, but I think the issue is that I am using the MM OS Docker image to run all this.
                    I think this means that the path expectations are different from the assumptions that I am making.
                    I may have to give in and just build the whole thing manually - it will probably be quicker than trying to fault find the install, given it’s obfuscation.
                      sdetweil @RobCee
                      @RobCee yes, docker paths and if OUTSIDE the MM tree, then YOU have to add new volume statements to the docker setup to map them
                        RobCee @sdetweil
                        @sdetweil yeah, I am deliberately keeping all the module paths in the default place, but it still doesn’t like it.
                        But if I go into the docker container, it doesn’t seem to have access to Python, so maybe that’s the problem.
                        It is all rather confusing. (More so from your end, no doubt)
                        • 1 / 5
