    Problem with Google generated .ics link
    30 Posts 2 Posters 9.8k Views 2 Watching
    • ankonaskiff17A Offline
      ankonaskiff17 @sdetweil
      @sdetweil I’m not worried about personal stuff in this one so you got complete.
      BEGIN:VEVENT
      DTSTART:20200512T124500Z
      DTEND:20200512T134500Z
      DTSTAMP:20220424T235526Z
      UID:74o68d9k61hj4b9pckom6b9kccsj2bb1cdgj6bb370sj0dpk6k
      CREATED:20210216T015059Z
      DESCRIPTION:
      LAST-MODIFIED:20210216T015059Z
      SEQUENCE:0
      STATUS:CONFIRMED
      SUMMARY:X-Ray & MRI
      TRANSP:OPAQUE
      END:VEVENT
      ankonaskiff17A S 2 Replies Last reply Reply Quote 0
        ankonaskiff17 @ankonaskiff17
        @ankonaskiff17 I know historically it would post my calendar info as a list, identical to the US Holiday link
          sdetweil @ankonaskiff17
          @ankonaskiff17 ok, we need to see which one is causing the problem… so edit config.js and change loglevel like this
          logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"], // Add "DEBUG" for even more logging
          then run MM like this
          npm start >somefile.txt
          wait for cal to come up
          ctrl-c to end MM
          then examine someflle.txt
          u may need to send me the file
          same userid at gmail. I don’t share
            my event looks like this
            BEGIN:VEVENT
            DTSTART:20220126T150000Z
            DTEND:20220126T210000Z
            DTSTAMP:20220425T000759Z
            UID:6oq3edpnc9ijeb9nc9h30b9k6tj3ibb2c5j3eb9k75hj6opk6dhjce32cg@google.com
            CREATED:20220111T023256Z
            DESCRIPTION:
            LAST-MODIFIED:20220111T023256Z
            SEQUENCE:0
            STATUS:CONFIRMED
            SUMMARY:drive to ft stockton
            TRANSP:OPAQUE
            END:VEVENT
            ankonaskiff17A 1 Reply Last reply Reply Quote 0
              @sdetweil Check your email
                @ankonaskiff17 replied
                  @sdetweil Sent another email. Do you want copy of log files referenced in terminal
                    @ankonaskiff17 Also, this laptop of mine keeps dropping its wifi connection so bear that in mind, generally momentary but aggravating.
                      @ankonaskiff17 i think this dropping is power control…
                      there is a commandline to turn power control for wifi off
                      I have the same problem on a pi 0 2 w (one of 3)
                        @sdetweil Every device in home is fine but laptop.
                        2nd HP I’ve had this happen to.
