    Problem with Google generated .ics link
    30 Posts 2 Posters 9.6k Views 2 Watching
      sdetweil @ankonaskiff17
      @ankonaskiff17 could u post one of the vevents from the ICS file?
      curl -sL   whatever_url  >xxx.ics
      xxx.ics is a text file
      ankonaskiff17A 1 Reply Last reply Reply Quote 0
      • ankonaskiff17A Offline
        ankonaskiff17 @sdetweil
        @sdetweil said in Problem with Google generated .ics link:
        What were you either expecting or hoping to see?
        Looks like a bunch of my calendar entries in like csv (or similar) format.
        I had earlier dropped link in MS Edge and it opened the Google calendar but in the MS Edge default calendar applet or whatever they call those bare bones apps
          @ankonaskiff17
          pick a
          BEGIN:VEVENT
          END:VEVENT
          change whatever is personal, dont change the date info please
          this is the format the calendar module passes to the parser…
          its needs to be in a specific format
          u don’t want a calendar tool to display it, we need to look at the raw text…
          (I spent 8 months in there solving all kinds of problems., and with the parser too)
            @sdetweil I’m not worried about personal stuff in this one so you got complete.
            BEGIN:VEVENT
            DTSTART:20200512T124500Z
            DTEND:20200512T134500Z
            DTSTAMP:20220424T235526Z
            UID:74o68d9k61hj4b9pckom6b9kccsj2bb1cdgj6bb370sj0dpk6k
            CREATED:20210216T015059Z
            DESCRIPTION:
            LAST-MODIFIED:20210216T015059Z
            SEQUENCE:0
            STATUS:CONFIRMED
            SUMMARY:X-Ray & MRI
            TRANSP:OPAQUE
            END:VEVENT
            ankonaskiff17A S 2 Replies Last reply Reply Quote 0
              ankonaskiff17 @ankonaskiff17
              @ankonaskiff17 I know historically it would post my calendar info as a list, identical to the US Holiday link
                @ankonaskiff17 ok, we need to see which one is causing the problem… so edit config.js and change loglevel like this
                logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"], // Add "DEBUG" for even more logging
                then run MM like this
                npm start >somefile.txt
                wait for cal to come up
                ctrl-c to end MM
                then examine someflle.txt
                u may need to send me the file
                same userid at gmail. I don’t share
                  my event looks like this
                  BEGIN:VEVENT
                  DTSTART:20220126T150000Z
                  DTEND:20220126T210000Z
                  DTSTAMP:20220425T000759Z
                  UID:6oq3edpnc9ijeb9nc9h30b9k6tj3ibb2c5j3eb9k75hj6opk6dhjce32cg@google.com
                  CREATED:20220111T023256Z
                  DESCRIPTION:
                  LAST-MODIFIED:20220111T023256Z
                  SEQUENCE:0
                  STATUS:CONFIRMED
                  SUMMARY:drive to ft stockton
                  TRANSP:OPAQUE
                  END:VEVENT
                    @sdetweil Check your email
                      @ankonaskiff17 replied
                        @sdetweil Sent another email. Do you want copy of log files referenced in terminal
