    Problem with Google generated .ics link
    30 Posts 2 Posters 11.3k Views 2 Watching
      my event looks like this
      BEGIN:VEVENT
      DTSTART:20220126T150000Z
      DTEND:20220126T210000Z
      DTSTAMP:20220425T000759Z
      UID:6oq3edpnc9ijeb9nc9h30b9k6tj3ibb2c5j3eb9k75hj6opk6dhjce32cg@google.com
      CREATED:20220111T023256Z
      DESCRIPTION:
      LAST-MODIFIED:20220111T023256Z
      SEQUENCE:0
      STATUS:CONFIRMED
      SUMMARY:drive to ft stockton
      TRANSP:OPAQUE
      END:VEVENT
      ankonaskiff17A 1 Reply Last reply Reply Quote 0
      • ankonaskiff17A Offline
        ankonaskiff17 @sdetweil
        @sdetweil Check your email
          sdetweil @ankonaskiff17
          @ankonaskiff17 replied
            @sdetweil Sent another email. Do you want copy of log files referenced in terminal
              ankonaskiff17 @ankonaskiff17
              @ankonaskiff17 Also, this laptop of mine keeps dropping its wifi connection so bear that in mind, generally momentary but aggravating.
                @ankonaskiff17 i think this dropping is power control…
                there is a commandline to turn power control for wifi off
                I have the same problem on a pi 0 2 w (one of 3)
                  @sdetweil Every device in home is fine but laptop.
                  2nd HP I’ve had this happen to.
                    @ankonaskiff17 I’m using VNC to access Pi. It’s just chugging along no wifi issues whatsoever
                      @ankonaskiff17 My mistake starting over fresh
                        @ankonaskiff17 I rebooted pi, MM launched did pm2 stop all,
                        got back to MM directory and did npm start and that is ugly. Line after line of the word NULL, then a mish mash of garbage tthen saw VEVENT related to holiday calendar but MM crashed in among all that.
                          @ankonaskiff17 @sdetweil check email for sample
                            ull,null,null,null,null,null,null,null,null,null,null,null]
                            [24.04.2022 21:25.05.341] [DEBUG] event.recurrences: undefined
                            [24.04.2022 21:25.05.359] [ERROR] Calendar Error. Could not fetch calendar: https://calendar.google.com/c/basic.ics RangeError: Invalid time value
                            at Date.toISOString ()
                            at /home/pi/MagicMirror/modules/default/calendar/calendarutils.js:314:28
                            at Array.forEach ()
                            at Object.filterEvents (/home/pi/MagicMirror/modules/default/calendar/calendarutils.js:142:24)
                            at /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:74:29
                            at processTicksAndRejections (node:internal/process/task_queues:96:5)
                            S ankonaskiff17A 2 Replies Last reply Reply Quote 0
                              @ankonaskiff17 i replied to email
                                That Holiday calendar has a huge amount of garbage associated with it as an aside but if newest is at top its just a lot more of that null business.
                                Scroll down you get to that error associated with google calendar that one time then a ton of garbage associated with the holiday calendar.
                                  @ankonaskiff17 weird… i don’t see that
                                    @sdetweil All that garbage associated with Holiday calendar is being pulled from the CalendarLabs site but since MM is loading it in list format it just gets lost in the ether?
                                      @ankonaskiff17 no idea, still debugging
                                        @ankonaskiff17 ok, can recreate… was testing on 2.18 … which didn’t fail…
                                        so that points to the node-ical lib which was changed for this release…
                                          @sdetweil You have any thoughts/ideas about what is going on?
                                          EST5EDT looks like some sort of mash up of Eastern Standard Time and Eastern Daylight Time and your node-ical comment look like a more complex issue. Are they intertwined?
                                          Neither of the two would be in my control in just dropping a Google generated URL in the config file.
                                            @ankonaskiff17 can u look at the entry in google calendar and see what the timezone setting is?
                                            how did u create that entry? phone, tablet, computer???
