    Problem with Google generated .ics link
    30 Posts 2 Posters 11.1k Views 2 Watching
    • ankonaskiff17A Offline
      ankonaskiff17 @ankonaskiff17
      @ankonaskiff17 Also, this laptop of mine keeps dropping its wifi connection so bear that in mind, generally momentary but aggravating.
        sdetweil @ankonaskiff17
        @ankonaskiff17 i think this dropping is power control…
        there is a commandline to turn power control for wifi off
        I have the same problem on a pi 0 2 w (one of 3)
        ankonaskiff17A 1 Reply Last reply Reply Quote 0
          ankonaskiff17 @sdetweil
          @sdetweil Every device in home is fine but laptop.
          2nd HP I’ve had this happen to.
            @ankonaskiff17 I’m using VNC to access Pi. It’s just chugging along no wifi issues whatsoever
              @ankonaskiff17 My mistake starting over fresh
                @ankonaskiff17 I rebooted pi, MM launched did pm2 stop all,
                got back to MM directory and did npm start and that is ugly. Line after line of the word NULL, then a mish mash of garbage tthen saw VEVENT related to holiday calendar but MM crashed in among all that.
                  @ankonaskiff17 @sdetweil check email for sample
                    ull,null,null,null,null,null,null,null,null,null,null,null]
                    [24.04.2022 21:25.05.341] [DEBUG] event.recurrences: undefined
                    [24.04.2022 21:25.05.359] [ERROR] Calendar Error. Could not fetch calendar: https://calendar.google.com/c/basic.ics RangeError: Invalid time value
                    at Date.toISOString ()
                    at /home/pi/MagicMirror/modules/default/calendar/calendarutils.js:314:28
                    at Array.forEach ()
                    at Object.filterEvents (/home/pi/MagicMirror/modules/default/calendar/calendarutils.js:142:24)
                    at /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:74:29
                    at processTicksAndRejections (node:internal/process/task_queues:96:5)
                    S ankonaskiff17A 2 Replies Last reply Reply Quote 0
                      @ankonaskiff17 i replied to email
                        That Holiday calendar has a huge amount of garbage associated with it as an aside but if newest is at top its just a lot more of that null business.
                        Scroll down you get to that error associated with google calendar that one time then a ton of garbage associated with the holiday calendar.
                          @ankonaskiff17 weird… i don’t see that
                            @sdetweil All that garbage associated with Holiday calendar is being pulled from the CalendarLabs site but since MM is loading it in list format it just gets lost in the ether?
                              @ankonaskiff17 no idea, still debugging
                                @ankonaskiff17 ok, can recreate… was testing on 2.18 … which didn’t fail…
                                so that points to the node-ical lib which was changed for this release…
                                  @sdetweil You have any thoughts/ideas about what is going on?
                                  EST5EDT looks like some sort of mash up of Eastern Standard Time and Eastern Daylight Time and your node-ical comment look like a more complex issue. Are they intertwined?
                                  Neither of the two would be in my control in just dropping a Google generated URL in the config file.
                                    @ankonaskiff17 can u look at the entry in google calendar and see what the timezone setting is?
                                    how did u create that entry? phone, tablet, computer???
                                      @sdetweil Per Google the only way to get the links is via the PC/Laptop Google Calendar. In their help links they spell that out pretty explicitly and that is how I did it and have always done it. The url generated on settings page is pretty straightforward with only possible error being if you choose public or private url.
                                      As far as time zone, I’ve attached an image but in screen capture the top Primary was and is correct just as shown. The secondary was some oddball city with time being GMT - 7 hours vs primary being GMT -4 so I changed secondary to be another GMT-4 city.
                                      I looked last night, but on phone, and it showed correct time.
                                      Is the 5 in EST5EDT what happens when toggling between EST & EDT & GMT? I dont have any idea if EU has an equivalent to daylight savings timeTime Zone .jpg
                                        @ankonaskiff17 said in Problem with Google generated .ics link:
                                        yes, other countries have DST/STD time shifts…
                                        typically the TZID is specified like this
                                        TZID=America/Barbados
                                        or
                                        TZID=America/Chicago
                                        I see that your ICS has a special definition of the TZID EST5DST
                                        BEGIN:VTIMEZONE
                                        TZID:EST5EDT
                                        X-LIC-LOCATION:EST5EDT
                                        BEGIN:DAYLIGHT
                                        TZOFFSETFROM:-0500
                                        TZOFFSETTO:-0400
                                        TZNAME:EDT
                                        DTSTART:19700308T020000
                                        RRULE:FREQ=YEARLY;BYMONTH=3;BYDAY=2SU
                                        END:DAYLIGHT
                                        BEGIN:STANDARD
                                        TZOFFSETFROM:-0400
                                        TZOFFSETTO:-0500
                                        TZNAME:EST
                                        DTSTART:19701101T020000
                                        RRULE:FREQ=YEARLY;BYMONTH=11;BYDAY=1SU
                                        END:STANDARD
                                        END:VTIMEZONE
                                        none of the code we have or use processes the TZ definitions. so that may be the issue…
                                        everything uses the IANA tz definitions.
                                        https://www.iana.org/time-zones
                                        i wrote the mapping code for special MS definitions to IANA definitions used in node-ical and mm calendar
                                        (from this table https://secure.jadeworld.com/JADETech/JADE2020/OnlineDocumentation/content/resources/encyclosys2/jadetimezone_class/ianawindowstimezonemapping.htm)
                                        but nothing accepts the EST5DST format,and neither read the timezone definitions in the ICS file.
                                          @sdetweil Sent you an email
