    Problem with Google generated .ics link
    30 Posts 2 Posters 10.3k Views 2 Watching
    • ankonaskiff17A Offline
      ankonaskiff17 @sdetweil
      @sdetweil I’m not worried about personal stuff in this one so you got complete.
      BEGIN:VEVENT
      DTSTART:20200512T124500Z
      DTEND:20200512T134500Z
      DTSTAMP:20220424T235526Z
      UID:74o68d9k61hj4b9pckom6b9kccsj2bb1cdgj6bb370sj0dpk6k
      CREATED:20210216T015059Z
      DESCRIPTION:
      LAST-MODIFIED:20210216T015059Z
      SEQUENCE:0
      STATUS:CONFIRMED
      SUMMARY:X-Ray & MRI
      TRANSP:OPAQUE
      END:VEVENT
      ankonaskiff17A S 2 Replies Last reply Reply Quote 0
        ankonaskiff17 @ankonaskiff17
        @ankonaskiff17 I know historically it would post my calendar info as a list, identical to the US Holiday link
          sdetweil @ankonaskiff17
          @ankonaskiff17 ok, we need to see which one is causing the problem… so edit config.js and change loglevel like this
          logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"], // Add "DEBUG" for even more logging
          then run MM like this
          npm start >somefile.txt
          wait for cal to come up
          ctrl-c to end MM
          then examine someflle.txt
          u may need to send me the file
          same userid at gmail. I don’t share
            my event looks like this
            BEGIN:VEVENT
            DTSTART:20220126T150000Z
            DTEND:20220126T210000Z
            DTSTAMP:20220425T000759Z
            UID:6oq3edpnc9ijeb9nc9h30b9k6tj3ibb2c5j3eb9k75hj6opk6dhjce32cg@google.com
            CREATED:20220111T023256Z
            DESCRIPTION:
            LAST-MODIFIED:20220111T023256Z
            SEQUENCE:0
            STATUS:CONFIRMED
            SUMMARY:drive to ft stockton
            TRANSP:OPAQUE
            END:VEVENT
            ankonaskiff17A 1 Reply Last reply Reply Quote 0
              @sdetweil Check your email
                @ankonaskiff17 replied
                  @sdetweil Sent another email. Do you want copy of log files referenced in terminal
                    @ankonaskiff17 Also, this laptop of mine keeps dropping its wifi connection so bear that in mind, generally momentary but aggravating.
                      @ankonaskiff17 i think this dropping is power control…
                      there is a commandline to turn power control for wifi off
                      I have the same problem on a pi 0 2 w (one of 3)
                        @sdetweil Every device in home is fine but laptop.
                        2nd HP I’ve had this happen to.
                          @ankonaskiff17 I’m using VNC to access Pi. It’s just chugging along no wifi issues whatsoever
                            @ankonaskiff17 My mistake starting over fresh
                              @ankonaskiff17 I rebooted pi, MM launched did pm2 stop all,
                              got back to MM directory and did npm start and that is ugly. Line after line of the word NULL, then a mish mash of garbage tthen saw VEVENT related to holiday calendar but MM crashed in among all that.
                                @ankonaskiff17 @sdetweil check email for sample
                                  ull,null,null,null,null,null,null,null,null,null,null,null]
                                  [24.04.2022 21:25.05.341] [DEBUG] event.recurrences: undefined
                                  [24.04.2022 21:25.05.359] [ERROR] Calendar Error. Could not fetch calendar: https://calendar.google.com/c/basic.ics RangeError: Invalid time value
                                  at Date.toISOString ()
                                  at /home/pi/MagicMirror/modules/default/calendar/calendarutils.js:314:28
                                  at Array.forEach ()
                                  at Object.filterEvents (/home/pi/MagicMirror/modules/default/calendar/calendarutils.js:142:24)
                                  at /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:74:29
                                  at processTicksAndRejections (node:internal/process/task_queues:96:5)
                                  S ankonaskiff17A 2 Replies Last reply Reply Quote 0
                                    @ankonaskiff17 i replied to email
                                      That Holiday calendar has a huge amount of garbage associated with it as an aside but if newest is at top its just a lot more of that null business.
                                      Scroll down you get to that error associated with google calendar that one time then a ton of garbage associated with the holiday calendar.
                                        @ankonaskiff17 weird… i don’t see that
                                          @sdetweil All that garbage associated with Holiday calendar is being pulled from the CalendarLabs site but since MM is loading it in list format it just gets lost in the ether?
                                            @ankonaskiff17 no idea, still debugging
