    Problem with Google generated .ics link
    30 Posts 2 Posters 9.8k Views 2 Watching
    • ankonaskiff17A Offline
      ankonaskiff17 @ankonaskiff17
      @ankonaskiff17 I know historically it would post my calendar info as a list, identical to the US Holiday link
        sdetweil @ankonaskiff17
        @ankonaskiff17 ok, we need to see which one is causing the problem… so edit config.js and change loglevel like this
        logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"], // Add "DEBUG" for even more logging
        then run MM like this
        npm start >somefile.txt
        wait for cal to come up
        ctrl-c to end MM
        then examine someflle.txt
        u may need to send me the file
        same userid at gmail. I don’t share
          my event looks like this
          BEGIN:VEVENT
          DTSTART:20220126T150000Z
          DTEND:20220126T210000Z
          DTSTAMP:20220425T000759Z
          UID:6oq3edpnc9ijeb9nc9h30b9k6tj3ibb2c5j3eb9k75hj6opk6dhjce32cg@google.com
          CREATED:20220111T023256Z
          DESCRIPTION:
          LAST-MODIFIED:20220111T023256Z
          SEQUENCE:0
          STATUS:CONFIRMED
          SUMMARY:drive to ft stockton
          TRANSP:OPAQUE
          END:VEVENT
          ankonaskiff17A 1 Reply Last reply Reply Quote 0
            ankonaskiff17 @sdetweil
            @sdetweil Check your email
              @ankonaskiff17 replied
                @sdetweil Sent another email. Do you want copy of log files referenced in terminal
                  @ankonaskiff17 Also, this laptop of mine keeps dropping its wifi connection so bear that in mind, generally momentary but aggravating.
                    @ankonaskiff17 i think this dropping is power control…
                    there is a commandline to turn power control for wifi off
                    I have the same problem on a pi 0 2 w (one of 3)
                      @sdetweil Every device in home is fine but laptop.
                      2nd HP I’ve had this happen to.
                        @ankonaskiff17 I’m using VNC to access Pi. It’s just chugging along no wifi issues whatsoever
