    MM not starting up
    7 Posts 3 Posters 3.9k Views 2 Watching
      A Former User
      Hey guys. I’ve just installed MM from github onto my raspberry pi 3. I have followed all the instructions on the git hub page down to a “T”, but when I write…
      pm2 start mm.sh
      …into the terminal window, nothing happens. I carried on following the rest of the instructions until the end, hoping that it might work after restarting the raspberry pi but still, nothing happens.
      Any ideas where I might be going wrong? Are the setup instructions still correct? I’m guessing they are.
      • brobergB Offline
        broberg Project Sponsor
        have you tried just to go in to the magicmirror folder and just type “npm start”? that will give you an indication if it’s the mirror that won’t start or if it’s the start script that doesn’t work.
        And, you have to be in the window handler for the magicmirror to run.
          jag @broberg
          @broberg If you set DISPLAY=:0 in your environment before starting MM, then you don’t have to be at the console.
          • brobergB Offline
            broberg Project Sponsor @jag
            @jag the LXDE still has to be running, the display=:0 is, If I’m not mistaken, if you run it remotely, right?
              jag @broberg
              @broberg Yes LXDE has to be running (preferably on boot).
              Then you you may login using ssh, and start MM manually.
              As long as you set the DISPLAY env variable correctly you can start X-apps on the display.
              • brobergB Offline
                @jag Had time to change my answer after a google search, sorry. we are on the same page :D
                  A Former User
                  Hey guys
                  Many thanks for all your replies. Not sure why it wasn’t working. I had to reinstall MM and now it’s working just fine. :)
