    Podcast
    12 Posts 5 Posters 8.4k Views 2 Watching
      PtrBld Module Developer
      Hi no you Do not need to Set the Position because the omxplayer does not start in the mirror display but as an overlay.
      I am running the git version of my module myself and do not get any errors (it is working as expected here). Unfortunatelly I am not home the next few days and and can not check the code right now…
      But I will if i find time.
      Until then you should check if you have installed all needed prerequisites. Maybe this is an issue?!
      • paviroP Offline
        paviro @witschi87
        @witschi87 it should indeed be correct as it is right now since you are overwriting a function adding self should break that especially since self is not even defined at that point.
        – The Doctor
        • paviroP Offline
          paviro
          If you meant setTimeout(function(){socketNotificationReceived(notification, payload)},2000); on the other hand, this should not work at all! What is this supposed to do?
          – The Doctor
          • W Offline
            witschi87
            @paviro Yes, I mean setTimeout(function(){socketNotificationReceived(notification, payload)},2000);. This is an even call to wait the download is finished. The downloadVideo-Function has a callback to set the this.loaded = true and after that the socketNotificationReceived-Function runs the omx.play()-Command. But at this point nothings happens…
              ok I see I will change that…
              Well if you never run into the ‘setTimeout’ call it works as expected :angel:
              But the video should be played. Can you tell me what podcast you are using and if the video is downloaded properly (can you play it from your directory)?
              • W Offline
                witschi87
                I’m using the 100 seconds Tagesschau podcast. The video is downloaded properly and I can play it from directory. I have also checked, that the omx.play()-Command is reached with a console.log. But nothing happens - no error message and no video is playing :(
                While we are at it: what is the best way to develop a module? Do I need to restart the application (pm2 restart/reload mm) every time I am changing a node_helper?
                  Yes. That is the way i am doing it
                    Have you tried playing the video using the omxplayer?
                    • W Offline
                      witschi87
                      via ssh-console? How can I do that?
                        jtyle6 @witschi87
                        @witschi87 said in Podcast:
                        https://www.raspberrypi.org/documentation/usage/audio/README.md
                        Basically, it’s:
                        omxplayer <File Name>
                          schmucke
                          @witschi87
                          dit you have resolve the problem? I ave the same issue - i can press the button, in the console appears BUTTON_PRESSED but nothing happen…
