Podcast
ok I see I will change that…
Well if you never run into the ‘setTimeout’ call it works as expected :angel:But the video should be played. Can you tell me what podcast you are using and if the video is downloaded properly (can you play it from your directory)?
I’m using the 100 seconds Tagesschau podcast. The video is downloaded properly and I can play it from directory. I have also checked, that the
omx.play()-Command is reached with aconsole.log. But nothing happens - no error message and no video is playing :(
While we are at it: what is the best way to develop a module? Do I need to restart the application (pm2 restart/reload mm) every time I am changing a node_helper? -
Yes. That is the way i am doing it
Have you tried playing the video using the omxplayer?
via ssh-console? How can I do that?
@witschi87 said in Podcast:
https://www.raspberrypi.org/documentation/usage/audio/README.md
Basically, it’s:
omxplayer <File Name> -
dit you have resolve the problem? I ave the same issue - i can press the button, in the console appears BUTTON_PRESSED but nothing happen…
