    Podcast
    12 Posts 5 Posters 8.1k Views 2 Watching
    • paviroP Offline
      paviro @witschi87
      @witschi87 it should indeed be correct as it is right now since you are overwriting a function adding self should break that especially since self is not even defined at that point.
      – The Doctor
      • paviroP Offline
        paviro
        If you meant setTimeout(function(){socketNotificationReceived(notification, payload)},2000); on the other hand, this should not work at all! What is this supposed to do?
        – The Doctor
        • W Offline
          witschi87
          @paviro Yes, I mean setTimeout(function(){socketNotificationReceived(notification, payload)},2000);. This is an even call to wait the download is finished. The downloadVideo-Function has a callback to set the this.loaded = true and after that the socketNotificationReceived-Function runs the omx.play()-Command. But at this point nothings happens…
            PtrBld Module Developer
            ok I see I will change that…
            Well if you never run into the ‘setTimeout’ call it works as expected :angel:
            But the video should be played. Can you tell me what podcast you are using and if the video is downloaded properly (can you play it from your directory)?
            • W Offline
              witschi87
              I’m using the 100 seconds Tagesschau podcast. The video is downloaded properly and I can play it from directory. I have also checked, that the omx.play()-Command is reached with a console.log. But nothing happens - no error message and no video is playing :(
              While we are at it: what is the best way to develop a module? Do I need to restart the application (pm2 restart/reload mm) every time I am changing a node_helper?
                Yes. That is the way i am doing it
                  Have you tried playing the video using the omxplayer?
                  • W Offline
                    witschi87
                    via ssh-console? How can I do that?
                      jtyle6 @witschi87
                      @witschi87 said in Podcast:
                      https://www.raspberrypi.org/documentation/usage/audio/README.md
                      Basically, it’s:
                      omxplayer <File Name>
                        schmucke
                        @witschi87
                        dit you have resolve the problem? I ave the same issue - i can press the button, in the console appears BUTTON_PRESSED but nothing happen…
