    Issue Calendar CustomEvents color
    6 Posts 2 Posters 1.7k Views 2 Watching
      sdetweil @mboss
      @mboss looks right
      the code
      			// Color events if custom color is specified
      			if (this.config.customEvents.length > 0) {
      				for (let ev in this.config.customEvents) {
      					if (typeof this.config.customEvents[ev].color !== "undefined" && this.config.customEvents[ev].color !== "") {
      						let needle = new RegExp(this.config.customEvents[ev].keyword, "gi");
      						if (needle.test(event.title)) {   <000000  this is the test, EXACT match (case insensitive.. spaces matter)
      							// Respect parameter ColoredSymbolOnly also for custom events
      							if (!this.config.coloredSymbolOnly) {
      								eventWrapper.style.cssText = "color:" + this.config.customEvents[ev].color;
      								titleWrapper.style.cssText = "color:" + this.config.customEvents[ev].color;
      							if (this.config.displaySymbol) {
      								symbolWrapper.style.cssText = "color:" + this.config.customEvents[ev].color;
      							break;
      so… I would download the ICS file
      curl -sL the_cal_url >xxx.ics
      then edit xxx.ics (just a text file, don’t OPEN it with file explorer right click open with … some text editor) and search for your keywords, exactly
      last time, some had TWO spaces between the words
        mboss @sdetweil
        @sdetweil Thanks for the response,
        so I have downloaded the .ics file and had a look though. I cut and pasted the event descriptions into my MM config file, unfortunately still no colour action.
        I have even tried using just one keyword to match “Black, Blue, Green” as those would be the identifiers for each event, again still nothing.
          sdetweil @mboss
          @mboss i just took your custom events structure and
          change the keyword to something in one of my events and color
          and it worked 1st try…
          the thing you are looking for is in the SUMMARY field, NOT the description field, right?
          SUMMARY:power windows  testing
          and the def
          					customEvents: [
          						/*Black Bin (your comment)*/
          						keyword: 'windows',
          						color: 'red'
          and I rechecked with multiple words separated by one space, good…
          and more than 1 space, but keyword has 1 space, not changed… (as expected)
            mboss @sdetweil
            Apologies for the late follow-up things got busy around the house.
            So I went back to basics to debug what I was doing wrong… I added just the bin pick-up calendar and the custom events code to a clean config file. Worked right away, just when I went to use the module “MMM-monthlyCalendar” that would not show the custom events colour.
            Thank you for helping me, guess I’m on to looking for a new calendar module.
              sdetweil @mboss
              @mboss each module does its own thing…
