    MM v2.1 update with iframe
    4 Posts 2 Posters 2.5k Views 2 Watching
    • G Offline
      gshimself
      Hi. I just updated MM and it works pretty well. However…
      I have my MM in a Virtual Machine and have a own local website that acceess the MM with iframe, but can’t get it to work.
      I can access the MM through chrome direct IP but when it access through the website, it doesn’t work. I have whitelisted the whole network (192.168.X.X)
      im no pro at this so, any help will do.
      • G Offline
        gshimself
        After some googlesearch I’ve discoverd that now you can’t iFrame MM in chrome due to X-frame-options on the page.
        Is there a way to bypass this through MM or is it just time to revert to MM 2.0 again?
        EDIT Narrowed it down to that I must change the X-Frame-Options in the MM… I think.
        • G Offline
          gshimself
          I’ve sovled it.
          You have to edit /MagicMirror/node_modules/frameguard$/index.js and comment the line
          “// res.setHeader(‘X-Frame-Options’, directive)”
            A Former User @gshimself
            @gshimself
            Yes! I’ve been working on this for about 3 days now, and I never came across this page! Instantly solved my issue!
            One small change though. I commented out line: “res.setHeader(‘X-Frame-Options’, headerValue)”, in the file at: “/MagicMirror/node_modules/frameguard/dist/index.js”.
            Still it was your post that solved my issue.
            Thanks so much! :thumbs_up: :thumbs_up:
