    MMM-GoogleSheets not working
    5 Posts 3 Posters 1.4k Views 3 Watching
      SARCux
      Hi @all,
      MMM-GoogleSheets not running,
      i do all of step1 in the readme, but the module is not running.
      all other modules after that will not be loaded.
      This message displayed in Chrome
      TypeError: Cannot read property '0' of undefined (Zeile 11, Datei "Code")
      It seems to be a problem with Google, right? Can someone help
        @SARCux this module needs the request library but doesn’t have a package.json
        did u already do this
          SARCux @sdetweil
          Thx for this information,
          but I’ve already done that.
          You may remember the other issue where the calendar wasn’t showing and I was able to fix it with that.
            sdetweil @SARCux
            @SARCux i see the same problem…
            looks like google changed the process
            you’ll have to post an issue in the module’s github site
              ryandwilliams Module Developer @sdetweil
              @sdetweil In case anyone finds this post in the future.
              This problem is usually one of two causes:
              1. The google apps script was not deployed correctly and the request runs into a permission error page
              2. There is an error in the request due to bad script URL or other parameter
              I have updated the module to fail gracefully in these cases and hopefully provide a better error message. If you are still having problems feel free to add an issue to the repo. (https://github.com/ryan-d-williams/MMM-GoogleSheets/issues).
