    ERROR:node_controller.cc(585)] Trying to re-add dropped peer
    19 Posts 2 Posters 5.7k Views 2 Watching
      sdetweil @travishardiman
      @travishardiman this is an electron error. I don’t see it fixed.
      can u tell me more about your environment.
      what pi, node --version,npm --version
      • T Offline
        travishardiman @sdetweil
        @sdetweil Raspberry Pi 4 Model B Rev 1.2, 4GB
        pi@smartmirror:~ $ node --version
        v16.15.1
        pi@smartmirror:~ $ npm --version
        8.11.0
        pi@smartmirror:~ $ uname -a
        Linux smartmirror 5.15.32-v8+ #1538 SMP PREEMPT Thu Mar 31 19:40:39 BST 2022 aarch64 GNU/Linux
          @travishardiman ah, 64 bit version, aarch64
          please fall back to the 32 bit version, armv7l
          lots of untested things on aarch64
          • T Offline
            @sdetweil is there an easy way to back-up/restore my current config? I don’t think there’s a way to switch to 32 bit without reinstalling the OS is there?
            • T Offline
              travishardiman
              /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
              <--- Last few GCs --->
              [1:0x24003c4000] 207008094 ms: Mark-sweep (reduce) 475.8 (523.7) -> 475.7 (523.7) MB, 1993.6 / 3.9 ms  (average mu = 0.920, current mu = 0.050) last resort GC in old space requested
              [1:0x24003c4000] 207010245 ms: Mark-sweep (reduce) 475.7 (523.7) -> 475.6 (523.2) MB, 2150.4 / 6.2 ms  (average mu = 0.846, current mu = 0.000) last resort GC in old space requested
              <--- JS stacktrace --->
              [38327:0626/104544.125499:ERROR:node_controller.cc(585)] Trying to re-add dropped peer 46DBA04CA2320621.3742B9BD63F3CD94
              S 1 Reply Last reply Reply Quote -1
                @travishardiman when is that from?
                did u do manual install or my script?
                have seen that error before.
                • T Offline
                  @sdetweil I tried to update the error in the first message with the first line. I posted as new reply in case someone is searching for that.
                  I just found your scripts here so I’m going to try this today, thanks!
                  https://github.com/sdetweil/MagicMirror-backup-restore
                    @travishardiman said in ERROR:node_controller.cc(585)] Trying to re-add dropped peer:
                    I have a backup/restore tool that will save the config, css and the location of all the installed modules (github links)
                    and tghen on restore downloads and re-installs the modules from the links
                    • T Offline
                      travishardiman
                      The backup didn’t restore my custom.css, mmpm, or some of the configuration files for 2 of my plugins but luckily I had those backed up elsewhere. I’m back up and running again though and so far so good! I’ll post back with logs if I get black screens again. Thanks for your help!
                        @travishardiman the backup folder has a specific name which u can override with parameters to the scripts
                        • T Offline
                          travishardiman
                          Well nuts, I thought I was good but it’s black screen again:
                          0|MagicMir |
                          0|MagicMir | <--- Last few GCs --->
                          0|MagicMir |
                          0|MagicMir | [1:0x2dd94000] 359113688 ms: Scavenge 882.9 (978.3) -> 879.5 (978.5) MB, 4.7 / 0.0 ms  (average mu = 0.974, current mu = 0.583) task
                          0|MagicMir | [1:0x2dd94000] 359113908 ms: Scavenge 883.0 (978.5) -> 879.7 (978.8) MB, 5.4 / 0.0 ms  (average mu = 0.974, current mu = 0.583) allocation failure
                          0|MagicMir | [1:0x2dd94000] 359114166 ms: Scavenge 883.4 (978.8) -> 880.0 (986.8) MB, 16.4 / 0.1 ms  (average mu = 0.974, current mu = 0.583) allocation failure
                          0|MagicMir |
                          0|MagicMir |
                          0|MagicMir | <--- JS stacktrace --->
                          0|MagicMir |
                            @travishardiman looks like there may be a module eating storage
                            what do you have installed beyond the base?
                            • T Offline
                              @sdetweil MMM-GoogleMapsTraffic, MMM-MyGarbage, and MMM-GooglePhotos
                                @travishardiman hm…not seen problems related to those, but time to run disabling one at a time
                                add
                                disabled:true,
                                after the
                                  module:
                                line
                                and restart mm
                                • T Offline
                                  @sdetweil ok, I’m starting with the google photos module and see how it goes. Are there any other logs that might be helpful for debugging?
                                    @travishardiman the console which you know and the browser console
                                    ctrl-shift-i, select the console tab and scroll up
                                    red text is typically errors
                                    • T Offline
                                      @sdetweil long term update after trying a few things out, the MMM-GoogleMapsTraffic module was the culprit. I started going down the path of trying to update the javascript issues when I discovered that your fork fixed them already. I uninstalled the original and installed yours and I haven’t had the black screen once since.
                                      https://github.com/sdetweil/MMM-GoogleMapsTraffic
                                      Thanks!
                                        @travishardiman cool
