    ERROR:node_controller.cc(585)] Trying to re-add dropped peer
    19 Posts 2 Posters 5.7k Views 2 Watching
    • T Offline
      travishardiman @sdetweil
      @sdetweil I tried to update the error in the first message with the first line. I posted as new reply in case someone is searching for that.
      I just found your scripts here so I’m going to try this today, thanks!
      https://github.com/sdetweil/MagicMirror-backup-restore
        sdetweil @travishardiman
        @travishardiman said in ERROR:node_controller.cc(585)] Trying to re-add dropped peer:
        is there an easy way to back-up/restore my current config
        I have a backup/restore tool that will save the config, css and the location of all the installed modules (github links)
        and tghen on restore downloads and re-installs the modules from the links
        • T Offline
          travishardiman
          The backup didn’t restore my custom.css, mmpm, or some of the configuration files for 2 of my plugins but luckily I had those backed up elsewhere. I’m back up and running again though and so far so good! I’ll post back with logs if I get black screens again. Thanks for your help!
            @travishardiman the backup folder has a specific name which u can override with parameters to the scripts
            • T Offline
              travishardiman
              Well nuts, I thought I was good but it’s black screen again:
              0|MagicMir |
              0|MagicMir | <--- Last few GCs --->
              0|MagicMir |
              0|MagicMir | [1:0x2dd94000] 359113688 ms: Scavenge 882.9 (978.3) -> 879.5 (978.5) MB, 4.7 / 0.0 ms  (average mu = 0.974, current mu = 0.583) task
              0|MagicMir | [1:0x2dd94000] 359113908 ms: Scavenge 883.0 (978.5) -> 879.7 (978.8) MB, 5.4 / 0.0 ms  (average mu = 0.974, current mu = 0.583) allocation failure
              0|MagicMir | [1:0x2dd94000] 359114166 ms: Scavenge 883.4 (978.8) -> 880.0 (986.8) MB, 16.4 / 0.1 ms  (average mu = 0.974, current mu = 0.583) allocation failure
              0|MagicMir |
              0|MagicMir |
              0|MagicMir | <--- JS stacktrace --->
              0|MagicMir |
                @travishardiman looks like there may be a module eating storage
                what do you have installed beyond the base?
                • T Offline
                  @sdetweil MMM-GoogleMapsTraffic, MMM-MyGarbage, and MMM-GooglePhotos
                    @travishardiman hm…not seen problems related to those, but time to run disabling one at a time
                    add
                    disabled:true,
                    after the
                      module:
                    line
                    and restart mm
                    • T Offline
                      @sdetweil ok, I’m starting with the google photos module and see how it goes. Are there any other logs that might be helpful for debugging?
                        @travishardiman the console which you know and the browser console
                        ctrl-shift-i, select the console tab and scroll up
                        red text is typically errors
                        • T Offline
                          @sdetweil long term update after trying a few things out, the MMM-GoogleMapsTraffic module was the culprit. I started going down the path of trying to update the javascript issues when I discovered that your fork fixed them already. I uninstalled the original and installed yours and I haven’t had the black screen once since.
                          https://github.com/sdetweil/MMM-GoogleMapsTraffic
                          Thanks!
                            @travishardiman cool
