    ERROR:node_controller.cc(585)] Trying to re-add dropped peer
    19 Posts 2 Posters 5.3k Views 2 Watching
    • T Offline
      travishardiman
      My MagicMirror works fine for a few days and then the screen goes black. The errors in the log look like this:
      <--- Last few GCs --->
      [1:0x28003d0000] 209716297 ms: Mark-sweep (reduce) 611.5 (708.2) -> 611.4 (686.2) MB, 2337.4 / 4.3 ms  (average mu = 0.625, current mu = 0.046) last resort GC in old space requested
      [1:0x28003d0000] 209718766 ms: Mark-sweep (reduce) 611.4 (686.2) -> 611.3 (680.0) MB, 2469.7 / 4.9 ms  (average mu = 0.444, current mu = 0.000) last resort GC in old space requested
      <--- JS stacktrace --->
      [1971:0624/001659.568718:ERROR:node_controller.cc(585)] Trying to re-add dropped peer DCF39E05685563B4.545691B8F0544120
      [1973:0624/001659.568999:ERROR:node_controller.cc(585)] Trying to re-add dropped peer DCF39E05685563B4.545691B8F0544120
      Here is the pm2 info:
      │ status            │ online                                   │
      │ name              │ MagicMirror                              │
      │ namespace         │ default                                  │
      │ version           │ 2.19.0                                   │
      │ restarts          │ 3                                        │
      │ uptime            │ 36m                                      │
      │ script path       │ /home/pi/MagicMirror/installers/mm.sh    │
      │ script args       │ N/A                                      │
      │ error log path    │ /home/pi/.pm2/logs/MagicMirror-error.log │
      │ out log path      │ /home/pi/.pm2/logs/MagicMirror-out.log   │
      │ pid path          │ /home/pi/.pm2/pids/MagicMirror-0.pid     │
      │ interpreter       │ bash                                     │
      │ interpreter args  │ N/A                                      │
      │ script id         │ 0                                        │
      │ exec cwd          │ /home/pi/MagicMirror                     │
      │ exec mode         │ fork_mode                                │
      │ node.js version   │ N/A                                      │
      │ node env          │ N/A                                      │
      │ watch & reload    │ ✔                                        │
      │ unstable restarts │ 0                                        │
      │ created at        │ 2022-06-24T05:15:29.610Z                 │
       Revision control metadata
      │ revision control │ git                                            │
      │ remote url       │ https://github.com/MichMich/MagicMirror.git    │
      │ repository root  │ /home/pi/MagicMirror                           │
      │ last update      │ 2022-06-24T05:15:30.131Z                       │
      │ revision         │ a2d7cdcfb425c2a51715bbaf663c2feb267a9798       │
      │ comment          │ Merge pull request #2834 from MichMich/develop │
      │                  │ Release v2.1                                   │
      │ branch           │ master                                         │
       Divergent env variables from local env
      │ PWD            │ /home/pi/MagicMirror                               │
      │ SSH_CONNECTION │ 192.168.1.64 40866 192.168.1.14 22                 │
      │ SHLVL          │ 2                                                  │
      │ XDG_SESSION_ID │ 4                                                  │
      │ SSH_CLIENT     │ 192.168.1.64 40866 22                              │
      │ PATH           │ /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin: │
      • T Offline
        travishardiman @sdetweil
        @sdetweil long term update after trying a few things out, the MMM-GoogleMapsTraffic module was the culprit. I started going down the path of trying to update the javascript issues when I discovered that your fork fixed them already. I uninstalled the original and installed yours and I haven’t had the black screen once since.
        https://github.com/sdetweil/MMM-GoogleMapsTraffic
        Thanks!
          sdetweil @travishardiman
          @travishardiman this is an electron error. I don’t see it fixed.
          can u tell me more about your environment.
          what pi, node --version,npm --version
          • T Offline
            @sdetweil Raspberry Pi 4 Model B Rev 1.2, 4GB
            pi@smartmirror:~ $ node --version
            v16.15.1
            pi@smartmirror:~ $ npm --version
            8.11.0
            pi@smartmirror:~ $ uname -a
            Linux smartmirror 5.15.32-v8+ #1538 SMP PREEMPT Thu Mar 31 19:40:39 BST 2022 aarch64 GNU/Linux
              @travishardiman ah, 64 bit version, aarch64
              please fall back to the 32 bit version, armv7l
              lots of untested things on aarch64
              • T Offline
                @sdetweil is there an easy way to back-up/restore my current config? I don’t think there’s a way to switch to 32 bit without reinstalling the OS is there?
                • T Offline
                  travishardiman
                  /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                  [1:0x24003c4000] 207008094 ms: Mark-sweep (reduce) 475.8 (523.7) -> 475.7 (523.7) MB, 1993.6 / 3.9 ms  (average mu = 0.920, current mu = 0.050) last resort GC in old space requested
                  [1:0x24003c4000] 207010245 ms: Mark-sweep (reduce) 475.7 (523.7) -> 475.6 (523.2) MB, 2150.4 / 6.2 ms  (average mu = 0.846, current mu = 0.000) last resort GC in old space requested
                  [38327:0626/104544.125499:ERROR:node_controller.cc(585)] Trying to re-add dropped peer 46DBA04CA2320621.3742B9BD63F3CD94
                  S 1 Reply Last reply Reply Quote -1
                    @travishardiman when is that from?
                    did u do manual install or my script?
                    have seen that error before.
                    • T Offline
                      @sdetweil I tried to update the error in the first message with the first line. I posted as new reply in case someone is searching for that.
                      I just found your scripts here so I’m going to try this today, thanks!
                      https://github.com/sdetweil/MagicMirror-backup-restore
                        @travishardiman said in ERROR:node_controller.cc(585)] Trying to re-add dropped peer:
                        I have a backup/restore tool that will save the config, css and the location of all the installed modules (github links)
                        and tghen on restore downloads and re-installs the modules from the links
                        • T Offline
                          travishardiman
                          The backup didn’t restore my custom.css, mmpm, or some of the configuration files for 2 of my plugins but luckily I had those backed up elsewhere. I’m back up and running again though and so far so good! I’ll post back with logs if I get black screens again. Thanks for your help!
                            @travishardiman the backup folder has a specific name which u can override with parameters to the scripts
                            • T Offline
                              travishardiman
                              Well nuts, I thought I was good but it’s black screen again:
                              0|MagicMir |
                              0|MagicMir | <--- Last few GCs --->
                              0|MagicMir |
                              0|MagicMir | [1:0x2dd94000] 359113688 ms: Scavenge 882.9 (978.3) -> 879.5 (978.5) MB, 4.7 / 0.0 ms  (average mu = 0.974, current mu = 0.583) task
                              0|MagicMir | [1:0x2dd94000] 359113908 ms: Scavenge 883.0 (978.5) -> 879.7 (978.8) MB, 5.4 / 0.0 ms  (average mu = 0.974, current mu = 0.583) allocation failure
                              0|MagicMir | [1:0x2dd94000] 359114166 ms: Scavenge 883.4 (978.8) -> 880.0 (986.8) MB, 16.4 / 0.1 ms  (average mu = 0.974, current mu = 0.583) allocation failure
                              0|MagicMir |
                              0|MagicMir |
                              0|MagicMir | <--- JS stacktrace --->
                              0|MagicMir |
                                @travishardiman looks like there may be a module eating storage
                                what do you have installed beyond the base?
                                • T Offline
                                  @sdetweil MMM-GoogleMapsTraffic, MMM-MyGarbage, and MMM-GooglePhotos
                                    @travishardiman hm…not seen problems related to those, but time to run disabling one at a time
                                    add
                                    disabled:true,
                                    after the
                                      module:
                                    line
                                    and restart mm
                                    • T Offline
                                      @sdetweil ok, I’m starting with the google photos module and see how it goes. Are there any other logs that might be helpful for debugging?
                                        @travishardiman the console which you know and the browser console
                                        ctrl-shift-i, select the console tab and scroll up
                                        red text is typically errors
                                        • T Offline
                                          Thanks!
                                            @travishardiman cool
