Solved Struggling with Weather... module
@D3dl3g you ONLY setup from config.js
please try with NO apibase set
weather.js and weatherprovider.js i have set back to defaults.
i have set config.js as requested
weatherProvider: 'ukmetofficedatahub', lat: "52.###############", long: "-1.###############", //apiBase: 'https://api-metoffice.apiconnect.ibmcloud.com/v0/forecasts/point/daily/', apiKey: 'e52#############################', apiSecret: 'd3a#############################',
the result:-
@D3dl3g send me your API key… config from config.js via email or direct message so I can debug
did u look in the browser messages?
my email is my same userid at gmail
Just to update the forum, as to what happened behind closed doors
Sam kindly tested my code, and it worked for him.
I am recieving browser errors (previously requested but i wasnt looking in the right bit of the browser window)… he is not
Issues Tab
Console Tab
the last 5 entries here will reoccur, im guessing at every “retry” for weather infoattempted to use
useCorsProxy: true
to no availSam kindly posted into git hub issues.
https://github.com/MichMich/MagicMirror/issues/271 -
tested
ukmetofficehub
and it works out of the box (without setting theuseCorsProxy
flag).Looking into the provided config
which is messed up. It has to be:
weatherProvider: 'ukmetofficedatahub', lat: 52.###############, lon: -1.###############,
@karsten13 I tested w those in quotes, and it worked ok
did only test without, but there is another error
lon
vs.long
@karsten13 I just copy pasted and it worked.
weird
i too am getting this… showing me some 80+miles SEE of my actual location
@karsten13
also… replace the hash symbols with various numbers… im not posting my exact Lat/Long for obvious reasons…make sure ur doing
lat:
and
lon:
i had it set to lat & lon(G) which is incorrect. hence why it was 80+miles, way tf over there!
quote marks or none surronding the numbers doesnt appear to matter, for me at least
