    Default weather module not showing after MM update
    25 Posts 7 Posters 11.8k Views 7 Watching
    • 0
      01ZerosOnes01
      Please help after updating to MagicMirror² version v2.20.0 today the default weather modules are no longer displaying. Does anyone know of the fix for this issue?
      TIA John Janis
      mumblebajM 1 Reply Last reply
      • 0
        01ZerosOnes01 @Jarhead96097
        @Jarhead96097 I was lucky I had a backup of my config. So just a reinstall and copy and paste. Everything is working fine now.
        All the best.
        • mumblebajM
          mumblebaj Module Developer @01ZerosOnes01
          @01ZerosOnes01 Are there any errors? If you used npm start then see for any errors in the terminal. If you used pm2 then check the pm2 log for errors. The guys would require more information to be able to assist.
          0 1 Reply Last reply
          • 0
            01ZerosOnes01
            Here is the entry in the config file
            module: “weather”,
            position: “top_right”,
            weatherProvider: “openweathermap”,
            type: “current”,
            locationID: “4891010”, //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
            apiKey: “a77f2dd7cf1c2e3b156b4d757fb6axxx”
            module: “weather”,
            header: “Weather Forecast”,
            type: “forecast”,
            • mumblebajM
              @01ZerosOnes01 See my first reply. Any errors from where you started the mirror?
              • 0
                01ZerosOnes01 @mumblebaj
                @mumblebaj Hi, thanks for your response there are no errors on the screen when I run npm start. No loading of that module indication but there is space allocated for the weather module on the screen in the top right area. All other modules work. Everything was working before the update to the latest MM.
                mumblebajM 2 Replies Last reply
                • mumblebajM
                  @01ZerosOnes01 I am just upgrading. Just one last check, see in the Developers window if there are any errors there. shit + ctrl + i
                  • mumblebajM
                    @01ZerosOnes01 I think there may be an issue with the api key for OpenWeatherMap.
                    • 0
                      @mumblebaj I xxx out the last few digits
                      • 0
                        @mumblebaj If I enter shit + ctrl + i in the terminal nothing shows up but a dialog box with Cancel and OK
                        • mumblebajM
                          @01ZerosOnes01 Hi. Not in the terminal from the browser window that displays the mirror. I have created an Openweathermap api key and I get an unauthorized error in the Developers window. I guess I have to wait for it to activate first. Once it is active I will see if I can spot anything.
                          • 0
                            @mumblebaj Okay this is what I get when I run shift + ctrl + i
                            Load script: modules/default/weather/weather.js
                            :8080/modules/default/weather/weather.js:159 Uncaught SyntaxError: Unexpected token .
                            Jarhead96097J S B T 4 Replies Last reply
                            • Jarhead96097J
                              Jarhead96097 @01ZerosOnes01
                              @01ZerosOnes01 said in Default weather module not showing after MM update:
                              I’m receiving the same error after updating to 2.20.0. Here’s the text from the weather.js error line 159: " currentWeather: this.weatherProvider?.currentWeatherObject?.simpleClone() ?? null,(RED X)"
                              Jarhead96097
                              • 0
                                @Jarhead96097 Thanks for your info. Hopefully someone can come up with the fix.
                                  sdetweil @01ZerosOnes01
                                  @01ZerosOnes01 @Jarhead96097
                                  how did u upgrade,and from what version?
                                  I don’t see any significant code change here this release…
                                  Jarhead96097J 1 Reply Last reply
                                  • 0
                                    01ZerosOnes01
                                    I keep the mirror updated so I am assuming it was updated from the last version.
                                    I updated by first issuing git stash then git pull && npm install --only=prod --omit=dev
                                    followed by git stash apply
                                    All other default and third party modules work.
                                    Thank for your help it is appreciated.
                                    • mumblebajM
                                      @01ZerosOnes01 I had my API authorized and the module works just fine with your location data. The only change I made was not add quotes around the locationID.
                                      locationID: 4891010,
                                      • Jarhead96097J
                                        Jarhead96097 @sdetweil
                                        @sdetweil I also upgraded from 2.19.0, which had been upgraded from 2.18.0. No problems before today.
                                        Jarhead96097
                                        • Jarhead96097J
                                          Jarhead96097 @mumblebaj
                                          @mumblebaj Well, unfortunately, removing the quotes around locationID did not resolve the issue on my configuration. I still receive “Uncaught SyntaxError: Unexpected token” in weather.js:159.
                                          Jarhead96097
                                          • 0
                                            01ZerosOnes01
                                            Raspberry Pi 4 2GB
                                            Well this is what i have done so far.
                                            Removed SD card with broken default weather module.
                                            With new SD card installed fresh 64bit Pi OS
                                            Fresh manual install of MagicMirror
                                            “name”: “magicmirror”,
                                            “version”: “2.20.0”,
                                            “description”: “The open source modular smart mirror platform.”,
                                            “main”: “js/electron.js”,
                                            Entered my openweathermap credentials
                                            and
                                            Walla! the weather module works.
                                            I have no idea why the weather module broke after the MagicMirror update. I will be following this thread to see if it is a problem or it was just a fluke.
                                            Good luck and thanks to all that contribute.
                                            Now I just have to reload my third party modules and customizations.
                                            • Jarhead96097J
                                              @01ZerosOnes01 @sdetweil Glad to hear you’re up and running on a fresh install… I’m hoping to avoid having to rebuild mine. Any other thoughts?
                                              And thanks for your time in advance!
                                              Jarhead96097
                                              S 0 2 Replies Last reply
