    Default weather module not showing after MM update
    25 Posts 7 Posters 11.6k Views 7 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @01ZerosOnes01
      @01ZerosOnes01 I think there may be an issue with the api key for OpenWeatherMap.
      0 1 Reply Last reply Reply Quote 0
      • 0 Offline
        01ZerosOnes01 @mumblebaj
        @mumblebaj I xxx out the last few digits
        • 0 Offline
          @mumblebaj If I enter shit + ctrl + i in the terminal nothing shows up but a dialog box with Cancel and OK
            @01ZerosOnes01 Hi. Not in the terminal from the browser window that displays the mirror. I have created an Openweathermap api key and I get an unauthorized error in the Developers window. I guess I have to wait for it to activate first. Once it is active I will see if I can spot anything.
            • 0 Offline
              @mumblebaj Okay this is what I get when I run shift + ctrl + i
              Load script: modules/default/weather/weather.js
              :8080/modules/default/weather/weather.js:159 Uncaught SyntaxError: Unexpected token .
              Jarhead96097J S B T 4 Replies Last reply Reply Quote 0
              • Jarhead96097J Offline
                Jarhead96097 @01ZerosOnes01
                @01ZerosOnes01 said in Default weather module not showing after MM update:
                I’m receiving the same error after updating to 2.20.0. Here’s the text from the weather.js error line 159: " currentWeather: this.weatherProvider?.currentWeatherObject?.simpleClone() ?? null,(RED X)"
                Jarhead96097
                • 0 Offline
                  01ZerosOnes01 @Jarhead96097
                  @Jarhead96097 Thanks for your info. Hopefully someone can come up with the fix.
                    sdetweil @01ZerosOnes01
                    @01ZerosOnes01 @Jarhead96097
                    how did u upgrade,and from what version?
                    I don’t see any significant code change here this release…
                    Jarhead96097J 1 Reply Last reply Reply Quote 0
                    • 0 Offline
                      01ZerosOnes01
                      I keep the mirror updated so I am assuming it was updated from the last version.
                      I updated by first issuing git stash then git pull && npm install --only=prod --omit=dev
                      followed by git stash apply
                      All other default and third party modules work.
                      Thank for your help it is appreciated.
                        @01ZerosOnes01 I had my API authorized and the module works just fine with your location data. The only change I made was not add quotes around the locationID.
                        locationID: 4891010,
                          Jarhead96097 @sdetweil
                          @sdetweil I also upgraded from 2.19.0, which had been upgraded from 2.18.0. No problems before today.
                          Jarhead96097
                            Jarhead96097 @mumblebaj
                            @mumblebaj Well, unfortunately, removing the quotes around locationID did not resolve the issue on my configuration. I still receive “Uncaught SyntaxError: Unexpected token” in weather.js:159.
                            Jarhead96097
                            • 0 Offline
                              01ZerosOnes01
                              Raspberry Pi 4 2GB
                              Well this is what i have done so far.
                              Removed SD card with broken default weather module.
                              With new SD card installed fresh 64bit Pi OS
                              Fresh manual install of MagicMirror
                              “name”: “magicmirror”,
                              “version”: “2.20.0”,
                              “description”: “The open source modular smart mirror platform.”,
                              “main”: “js/electron.js”,
                              Entered my openweathermap credentials
                              and
                              Walla! the weather module works.
                              I have no idea why the weather module broke after the MagicMirror update. I will be following this thread to see if it is a problem or it was just a fluke.
                              Good luck and thanks to all that contribute.
                              Now I just have to reload my third party modules and customizations.
                                @01ZerosOnes01 @sdetweil Glad to hear you’re up and running on a fresh install… I’m hoping to avoid having to rebuild mine. Any other thoughts?
                                And thanks for your time in advance!
                                Jarhead96097
                                S 0 2 Replies Last reply Reply Quote 0
                                  sdetweil @Jarhead96097
                                  @Jarhead96097 would be interested in knowing if my upgrade script avoided this problem
                                  FoziF 1 Reply Last reply Reply Quote 1
                                    Bearded1ne253 @01ZerosOnes01
                                    @01ZerosOnes01 you do not have a “ to start your string, only one at the end…
                                    • 0 Offline
                                      @Jarhead96097 I was lucky I had a backup of my config. So just a reinstall and copy and paste. Everything is working fine now.
                                      All the best.
                                      • FoziF Offline
                                        Fozi Project Sponsor @sdetweil
                                        @sdetweil I updated with your script and had no issues at all. Everything is fine.
                                        • T Offline
                                          Trabi11 @01ZerosOnes01
                                          I’m running into the exact same issue as explained above since I updated my MM.
                                          However, I only get this error message in chromium on the rasperry pi itself when I call the URL of the MM. All other devices in my network can display the Weather Module cleanly when I access the page via LAN IP. Both chromium and firefox on my notebook and my smartphone are displaying the default weather module cleanly.
