    Use local ICS file instead
    15 Posts 4 Posters 6.7k Views 4 Watching
    • plainbrokeP
      plainbroke
      Maybe my pm2 error log will help.
      looks like I am missing a file but can not figure out how to install it or what to install.
      /home/pi/.pm2/logs/omx-stream1-error.log last 15 lines:
      0|omx_stre | dbus[632]: Unable to set up transient service directory: XDG_RUNTIME_DIR "/run/user/1000" not available: No such file or directory
      0|omx_stre | /usr/bin/omxplayer: line 67: 85464 Killed                  LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
      0|omx_stre | dbus[626]: Unable to set up transient service directory: XDG_RUNTIME_DIR "/run/user/1000" not available: No such file or directory
      0|omx_stre | dbus[629]: Unable to set up transient service directory: XDG_RUNTIME_DIR "/run/user/1000" not available: No such file or directory
      0|omx_stre | dbus[627]: Unable to set up transient service directory: XDG_RUNTIME_DIR "/run/user/1000" not available: No such file or directory
      0|omx_stre | dbus[83012]: arguments to dbus_message_new_method_call() were incorrect, assertion "destination == NULL || _dbus_check_is_valid_bus_name (destination)" failed in file ../../../dbus/dbus-message.c line 1364.
      0|omx_stre | This is normally a bug in some application using the D-Bus library.
      0|omx_stre |
      0|omx_stre |   D-Bus not built with -rdynamic so unable to print a backtrace
      0|omx_stre | /usr/bin/omxplayer: line 67: 83012 Aborted                 (core dumped) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
      0|omx_stre | dbus[624]: Unable to set up transient service directory: XDG_RUNTIME_DIR "/run/user/1000" not available: No such file or directory
      /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
      1|mm       | MESA-LOADER: failed to retrieve device information
      1|mm       | MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/aarch64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri)
      1|mm       | failed to load driver: kms_swrast
      1|mm       | MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/aarch64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri)
      1|mm       | failed to load swrast driver
      1|mm       | [2651:0709/163251.289963:ERROR:broker_posix.cc(40)] Recvmsg error: Connection reset by peer (104)
      1|mm       | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
      1|mm       | [2838:0709/163305.686316:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
      • karsten13K
        karsten13 @plainbroke
        @plainbroke
        This will not work: "http://localhost:8181/Birthdays.ics"
        You can try to move the local ics file into the config directory and then use "webcal://localhost:8181/config/Birthdays.ics" as url.
          sdetweil @karsten13
          @karsten13 webcal is just replaced with http
          line 99 of calendar.js
          the root of the web server is ~/MagicMirror
          plainbrokeP 1 Reply Last reply
          • plainbrokeP
            plainbroke @sdetweil
            I finally have calendar working again. Had to completely replace my config.js with the sample one. Then rebuild it. I could get everyone of my calendars to work in the stripped down config.js so I just removed my calendars settings from my original config.js then copied and pasted the working calendar settings from the stripped down one saved and rebooted calendars work fine now. NOW on to the MMM-CalendarExt3 not picking up from the default calendar for some reason… Thats a problem for another day…
              sdetweil @plainbroke
              @plainbroke weird. I wonder what the config js problem wskdontgerebis a setting to cause broadcastEvents, which Ext3 depends on
              • plainbrokeP
                Not sure why either.
                I removed and reinstalled default calendar and it still works fine.
                Did that thinking maybe I had something corrupt in the calendar module. Didn’t make a difference.
                I will try to remove and reinstall CalendarExt3 tomorrow and see if that fixes the problem. If not I’ll be bugging the maker of CalendarExt3 again. He has been very helpful getting it up and running the way I want it to…
                M 1 Reply Last reply
                  MMRIZE @plainbroke
                  @plainbroke
                  Here I am. If you don’t mind, could u send the issued config.js and the url of ical? (You can copy the original calendar then remove too private events then deliver it to me.)
                  Tou can contact me at any time with eouia0819@gmail
                  • plainbrokeP
                    plainbroke
                    Here you go, the URLs are public so you can see what I am doing wrong easier…
                            module: "MMM-CalendarExt3",
                            position: "middle_center",
                            title: "Burdick Calendar",
                                    mode: "week",
                                    weekIndex: 0,
                                    weeksInView: 4,
                                    minimalDaysOfNewYear: 1,
                                    instanceId: "basicCalendar",
                                    locale: "en-US",
                                    maxEventLines: 5,
                                    firstDayOfWeek: 0,
                                    calendarSet: ["Holidays", "Birthdays"],
                                    eventHeight: "28px",
                                    maxWidth: "100%",
                                    maxHeight: "98%"
                            header: "Birthdays",
                                    fade: false,
                                    maximumEntries: 11,
                                    timeFormat: "absolute",
                                    urgency: 3,
                                    getRelative: 24,
                                            symbol: "birthday-cake",
                                            url: "https://calendar.google.com/calendar/ical/plainbroke%40gmail.com/public/basic.ics",
                            header: "Holidays",
                                    fade: false,
                                    maximumEntries: 11,
                                    urgency: 3,
                                    getRelative: 24,
                                            symbol: "calendar-check",
                                            url: "https://calendar.google.com/calendar/ical/en.usa%23holiday%40group.v.calendar.google.com/public/basic.ics",
                      MMRIZE @plainbroke
                      @plainbroke
                      I found two things;
                      1. Your calendars have no name (that is not the header), but you tried to refer to them in the calendarSet of the module.
                      So, you need to entitle the name to refer specific calendar;
                      1. You’d better set a color to the calendar.
                      The result will be;
                      • plainbrokeP
                        plainbroke @MMRIZE
                        @MMRIZE
                        You are the Man, I knew it was something simple that I was overlooking. As they used to say, “I sometimes can’t see the forest for the trees”…
