    Module Ability to Add Packages to Vendor Directory
    Scheduled Pinned Locked Moved Solved Feature Requests
    3 Posts 3 Posters 985 Views 3 Watching
    • T Offline
      td
      Hello!
      I am posting this here, but I am not sure if this feature already exists in some way or another.
      As I developed the Magic Mirror module MMM-GConnect (https://github.com/tderflinger/MMM-GConnect) I wanted to use the Preact (https://preactjs.com/) library to make my UI programming more efficient for me. Preact is basically a lightweight version of the popular React library.
      The only way to make Preact work in my module was to install it in the vendor directory and add a reference in vendor/vendor.js.
      The thing now is when users of my module want to install MMM-GConnect, they need to manually install Preact and add the lines to vendor/vendor.js.
      Is there a standard way to do that in Magic Mirror that I am not aware of? If not, I would propose to add a feature to make it possible for modules to add packages to vendor automatically as part of their install routine.
      Thanks for your opinion!
      -Thomas
      • T Offline
        td @MMRIZE
        @MMRIZE , yes, your getScripts function suggestion worked! Thanks!
          MMRIZE @td
          @td
          • This doesn’t work?
          getScripts: function () {
            return [
              this.file('node_modules/preact/dist/preact.min.js'), //from this module's directory
          • Or you can serve preinstall or postinstall scripts for your module to handle that kind of job (additional install, move/rename files, etc.)
          • T Offline
            td @MMRIZE
