Raspberry Pi display not autostarting magic mirror
6 Posts 2 Posters 1.0k Views 2 Watching
  • E Offline
    EphraimB
    My Raspberry Pi isn’t autostarting Magic Mirror with the 7 inch display connected. It autostarts correctly when connected to a monitor however. Is there something in the pm2 script that I have to do?
    S 1 Reply Last reply Jul 22, 2022, 1:00 PM Reply Quote 0
    • E Offline
      EphraimB @EphraimB
      @EphraimB I got it to work now. Thank you.
      S 1 Reply Last reply Jul 22, 2022, 5:53 PM Reply Quote 0
        sdetweil @EphraimB
        @EphraimB when the 7 in is used open a terminal session ctrl-alt-t
        and do
        echo $DISPLAY
        the line in package.json used for npm start, checks for DISPLAY set in the env, and if not uses :0
        this is needed by x-windows
        you might need to add
        export DISPLAY=:?
        to the installers/mm.sh, before the npm start line
        where ? is the display number used for the 7in
        E 1 Reply Last reply Jul 22, 2022, 1:10 PM Reply Quote 0
        • E Offline
          EphraimB @sdetweil
          /home/ephraimb/.pm2/logs/mm-error.log last 15 lines:
          0|mm       | [8401:0722/083808.387458:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
          0|mm       | [8449:0722/083808.554707:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
          0|mm       | [8410:0722/083808.663954:ERROR:command_buffer_proxy_impl.cc(126)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
          0|mm       | /home/ephraimb/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
          0|mm       | [8816:0722/083948.777454:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
          0|mm       | [8860:0722/083948.944901:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
          0|mm       | [8825:0722/083949.008201:ERROR:command_buffer_proxy_impl.cc(126)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
          0|mm       | [9539:0722/084423.587492:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
          0|mm       | [9583:0722/084423.754159:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
          0|mm       | [9546:0722/084423.836816:ERROR:command_buffer_proxy_impl.cc(126)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
          0|mm       | [1692:0722/090756.740898:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
          0|mm       | [1734:0722/090757.250763:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
          ^C
          ephraimb@raspberrypi:~ $ echo $DISPLAY
          E 1 Reply Last reply Jul 22, 2022, 1:22 PM Reply Quote 0
          • E Offline
            EphraimB @EphraimB
            @EphraimB https://youtu.be/7VVcJsOaJJc
            E 1 Reply Last reply Jul 22, 2022, 4:36 PM Reply Quote 0
            • E Offline
              EphraimB @EphraimB
                sdetweil @EphraimB
                @EphraimB what did u change?
