Show/Hide modules with vocal commands
6 Posts 2 Posters 1.1k Views 2 Watching
    Anthony Project Sponsor
    Hello everyone. I would like to know what part of code I should add into a modules code so I can show/hide it by voice. I use MMM-GoogleAssistant from bugsounet. For example I use MMM-WiFiPawwsword which has a function for vocal commands but to use with MMM-Modal. I wanted to be hidden on start and show only when I ask GA. I know I have to make a recipe for GA but what part of code should I change to the module to accept commands from GA and with what to replace it. Thank you in advance.
    S 1 Reply Last reply Jul 28, 2022, 11:08 AM Reply Quote 0
      sdetweil @Anthony
      @Anthony the module should already have suspend and resume functions.
      so nothing in the module needs to change
      in the recipe just hide()or show() the module
      A 1 Reply Last reply Jul 28, 2022, 11:32 AM Reply Quote 0
        Anthony Project Sponsor @sdetweil
        @sdetweil Thank you for your reply. I’ll check when I go home and give it a try. Unforunately I am not familiar with coding but I will try to make the recipe through some samples. Thank you again my friend.
        A 1 Reply Last reply Jul 28, 2022, 5:55 PM Reply Quote 0
          Anthony Project Sponsor @Anthony
          @Anthony said in Show/Hide modules with vocal commands:
          @sdetweil Hello again. Sorry for bothering you again. At this link is the MMM-WiFiPawwsword.js file. Can you please spot and show me where is show/hide function? Again sorry for bother but as you can understand I am totally newbie to this so it is difficult for me spot it. Thank you.
          S 1 Reply Last reply Jul 28, 2022, 7:11 PM Reply Quote 0
            sdetweil @Anthony
            @Anthony if the module does not provide it directly, the mm runtime does the suspend/resume for the module
            A 1 Reply Last reply Jul 29, 2022, 8:51 AM Reply Quote 0
              @sdetweil I see. I will definetly check it and try it. Thank you for your time.
