Unsolved Magic Mirror - RTSP not integrated
@MMRIZE
I will be happy to test when I get back home. You have my email already.
Send me a link or whatever so I can try it when I get back or if can get this chrome book changed over so i can run a MagicMirror on it… -
@MMRIZE
Hey I am back where I can test this RTSP module you have whipped up…
Heck I would be fine if I could get RTSPStream to work with vlc since I use full screen when the camera feeds come around in the MMM-Carousel module.
email same as user @gmail.com. What you are showing would be great if I can use it at full screen above or something like that… -
@BKeyport
Where can I get your blank space module and the whatever Player you use? -
@plainbroke the blank space module is “MMM-Block” - on the 3rd party module list.
I then use OMX, so you have to use either pre-current RPI OS, or figure out how to install it, as it’s abandon-ware.
@BKeyport
I have been looking at both and neither will work with my MM.
I thank you for the information though I thought for a bit I could make it work, but I finally just gave up. My head was hurting from all the reading and searching to get it all to work. You must have the patients of Job to get that to work. More likely you understand code WAY better than I do… All this code is way above my understanding… -
@MMRIZE ,
You get that RTSP module to work yet. I am very interested in it since MMM-RTSPStream has quit working altogether for me.
Not sure what I did different this time but even vlc fails to show a picture… -
@plainbroke
I’m still testing for optimal setting of rpi3. My approach(real time transcoding rtsp 2 mpeg to be implemented on html) seems somewhat burden for weak/old SBCs. Other more powered devices have enough to deal however. I’m not using rpi3 anymore, but not everyone.
Anyway I’m in summer leaves, so not have time at this moment. Maybe after 2 weeks I’ll continue. Plz wait a while. -
@MMRIZE
That is great to know. Thanks for the update, no worries.
I actually have RTSPStream up and running now using VLC.
So I am in no rush. -
@mmrize It working perfectly within my mirror, other than occasional pauses in stream… I use a PI4, and I’m currently in a heat wave, so it’s not running at full bore (I don’t have AC where the mirror is)
– edit:
OK - after a bit of burn-in, it’s falling all over itself. :(I think I’d be better off using snapshots. Problem is, only module I can find that can work with the snapshot system of my camera is RTSPStream, which just blows chunks otherwise.
