    MMM-Scenes
    12 Posts 5 Posters 4.9k Views 5 Watching
    • MZ-BERM Offline
      MZ-BER @MMRIZE
      @mmrize That is amazing! Thanks for sharing your module. Really good documentation.
      • doctorwhenD Offline
        doctorwhen
        Very cool. Thanks for the excellent module, i’m integrating it into my mirror without much difficulty. The only problem I’ve run into thus far is with the example config which I had to modify slightly to get it working on my setup.
        All I changed was the weather apikey but that didn’t work (blank screen, electron exits). I then changed the declaration of config from const to var and the example config works:
        const config = {
        to
        var config = {
        Otherwise, wow!
          MMRIZE @MMRIZE
          UPDATED
          1.1.0 (2021-11-01)
          • ADDED : MMM-TelegramBot commandable. (Thanks to @doctorfree)
          • N Offline
            Norder
            Hello! Thank you for the amazing work you’ve done. The scenes module was exactly what I needed to pop my MM up a notch. I do have some questions, however.
            How do you apply an expel/admit animation to specific modules only and not the whole scene?
            Can you do this for transitions between specific scenes? i.e. pageDown animation if arriving from scene 2, pageUp if arriving from scene 3?
            I’m wondering if there is a simple way to accomplish this, like an extra class tag within a module itself to call the animation type? My end goal is to have swipe gestures change scenes and have the animations change based upon the previous scene.
            Thanks again!
            M 3 Replies Last reply Reply Quote 0
              MMRIZE @Norder
              @Norder Thanks for your interesting. I’m on the holidays so cannot look inside deeply.
              After return, I’ll reply you sorry.
                MMRIZE @Norder
                @Norder
                You can do it with “custom animation function” https://github.com/MMRIZE/MMM-Scenes#--custom-animation-function
                You can define specific animation and module which you want to apply, then describe it in the “scenario”. Ideally it’s all, but real-world sample i will show you in a week (after my return)
                  MMRIZE @Norder
                  @Norder
                  To assign specific animation to the specific module, you can use “custom animation function” in your “scenario”.
                  To specify the module, you can use module property in animation function. For example, you can use module.name , module.data.classes or module.data.position (or whatever you want) (https://docs.magicmirror.builders/development/core-module-file.html#available-module-instance-properties)
                    scenario: [
                        expelAnimation: ({ module, moduleWrapper, duration }) => {
                          if (module.name === 'clock') {
                            return new Promise((resolve, reject) => {
                              moduleWrapper.animate([
                                { transform: 'scale(1,1)', opacity: 1 },
                                { transform: 'scale(10, 10)', opacity: 0 }
                              ], { duration }).onfinish = resolve
                          } else {
                                { transform: 'scale(1, 1)', opacity: 1 },
                                { transform: 'rotate(-360deg) scale(0, 0)', opacity: 0 }
                  Well, this example looks not so simple, I hope you can follow it.
                  S N 2 Replies Last reply Reply Quote 0
                    sdetweil @MMRIZE
                    @MMRIZE said in MMM-Scenes:
                    javascript programming question
                    why do you use {} around the function parms? usually this creates an object, which same labeled properties
                    but you don’t use them like properties of an object in the function
                    what extra value did u get from the braces?
                      MMRIZE @sdetweil
                      let x = {
                        foo: 123,
                        bar: 456,
                        baz: "please don't touch me"
                      function A (obj) {
                        console.log(obj.foo)
                        console.log(obj.bar)
                        // obj.baz = 'oops I did it again"
                      function B (Foo, Bar) {
                        console.log(Foo)
                        console.log(Bar)
                        // safe for .baz or object itself
                        // However, you must keep the order and number of parameters.
                      function C ({bar, foo}) {
                        console.log(foo)
                        console.log(bar)
                        // You don't need to keep the order and number of parameters.
                      function C2 (obj) {
                        let {bar, foo} = obj
                        console.log(foo)
                        console.log(bar)
                        // obj.baz = 'oops I did it again'
                      A(x)
                      B(x.foo, x.bar)
                      C(x)
                      C2(x)
                        sdetweil @MMRIZE
                        @MMRIZE thanks, I had not seen anonymous object before., or the hidden object property
