    MM and Shelly relay integration request - switch TV Off
    6 Posts 2 Posters 1.7k Views 2 Watching
      sdetweil @sforza
      @sforza does this script work from the terminal window?
      https://forums.raspberrypi.com/viewtopic.php?t=331355
        sforza @sdetweil
        @sdetweil I don’t own any shelly relay at the moment. Just trying to explore options to plan my actual mirror build 😊.
        Your link seems to be going in the right direction. Not sure if the relays in the smart plugs would share same API methods. Will consider buying one and trying.
        Thanks a lot!
          sforza @sforza
          @sforza said in MM and Shelly relay integration request - switch TV Off:
          if the relays and the smart plugs - typo
            sdetweil @sforza
            @sforza u can edit posts.
              sforza @sdetweil
              @sdetweil yes I’m aware 😊 I tried that first but system won’t allow after certain time apparently. I got an error message.
              Thanks for the suggestion and the continuos support in this forum!
