    Black Screen after installing fonts-noto-color-emoji
    26 Posts 4 Posters 7.8k Views 4 Watching
      aunrea @sdetweil
      Didn’t realize the path mattered.
      > magicmirror@2.20.0 config:check
      > node js/check_config.js
      /home/pi/MagicMirror/node_modules/@eslint/eslintrc/dist/eslintrc.cjs:2383
      const require$1 = Module.createRequire(require('url').pathToFileURL(__filename).toString());
      TypeError: Module.createRequire is not a function
          at Object.<anonymous> (/home/pi/MagicMirror/node_modules/@eslint/eslintrc/dist/eslintrc.cjs:2383:26)
          at Module.require (internal/modules/cjs/loader.js:692:17)
          at require (internal/modules/cjs/helpers.js:25:18)
          at Object.<anonymous> (/home/pi/MagicMirror/node_modules/eslint/lib/cli-engine/cli-engine.js:33:5)
      I don’t understand this.
      kayakbabeK S 3 Replies Last reply Reply Quote 0
      • kayakbabeK Offline
        kayakbabe @aunrea
        @aunrea did you run?
        first switch to the MagicMirror folder like this
        cd /home/pi/MagicMirror/
        then run this command
        npm run config:check
          sdetweil @aunrea
          @aunrea see
          https://github.com/MichMich/MagicMirror/issues/2772
          you need to upgrade node and npm to minimum levels
          use my install script next time
            sdetweil @aunrea
            @aunrea said in Black Screen after installing fonts-noto-color-emoji:
            mm is just an app installed on the system
              aunrea
              I have updated npm and node (in MagicMirror directory). I still have a black screen (I have done a reboot). When I run the config check I get a message saying there is no errors.
              [12.08.2022 15:58.52.189] [INFO]  Checking file...  /home/pi/MagicMirror/config/                                       config.js
              [12.08.2022 15:58.52.486] [INFO]  Your configuration file doesn't contain syntax                                        errors :)
                sdetweil @aunrea
                @aunrea after upgrading, you have to reinstall mm
                and maybe any modules
                still black screen maybe this
                show is the messages at mm start
                if using pm2 then
                pm2 --lines=50
                  aunrea @sdetweil
                  I did a clean install of mm, added my modules, copied the saved config from the previous install to the new install. Everything looked fine, then I rebooted and now I again have a black screen!!!
                  The npm log says:
                   verbose cli /usr/bin/node /usr/bin/npm
                  1 info using npm@8.11.0
                  2 info using node@v16.16.0
                  3 timing npm:load:whichnode Completed in 2ms
                  4 timing config:load:defaults Completed in 12ms
                  5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 7ms
                  6 timing config:load:builtin Completed in 9ms
                  7 timing config:load:cli Completed in 9ms
                  8 timing config:load:env Completed in 3ms
                  9 timing config:load:file:/home/pi/MagicMirror/.npmrc Completed in 0ms
                  10 timing config:load:project Completed in 26ms
                  11 timing config:load:file:/home/pi/.npmrc Completed in 0ms
                  12 timing config:load:user Completed in 3ms
                  13 timing config:load:file:/usr/etc/npmrc Completed in 1ms
                  14 timing config:load:global Completed in 2ms
                  15 timing config:load:validate Completed in 2ms
                  16 timing config:load:credentials Completed in 19ms
                  17 timing config:load:setEnvs Completed in 7ms
                  18 timing config:load Completed in 96ms
                  19 timing npm:load:configload Completed in 97ms
                  20 timing npm:load:mkdirpcache Completed in 5ms
                  21 timing npm:load:mkdirplogs Completed in 5ms
                  22 verbose title npm start
                  23 verbose argv "start"
                  24 timing npm:load:setTitle Completed in 6ms
                  25 timing config:load:flatten Completed in 18ms
                  26 timing npm:load:display Completed in 23ms
                  27 verbose logfile logs-max:10 dir:/home/pi/.npm/_logs
                  28 verbose logfile /home/pi/.npm/_logs/2022-08-13T00_05_23_038Z-debug-0.log
                  29 timing npm:load:logFile Completed in 36ms
                  30 timing npm:load:timers Completed in 1ms
                  31 timing npm:load:configScope Completed in 1ms
                  32 timing npm:load Completed in 182ms
                  33 silly logfile start cleaning logs, removing 1 files
                  34 silly logfile done cleaning log files
                  The pm2 error log says:
                  [8711:0812/191224.893179:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                  [8764:0812/191225.738183:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                  [8716:0812/191225.822559:ERROR:command_buffer_proxy_impl.cc(126)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                  [1644:0812/194324.158131:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                  [1694:0812/194325.043000:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                  [1718:0812/194325.555134:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                  [1672:0812/194325.644795:ERROR:command_buffer_proxy_impl.cc(126)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                  [12.08.2022 19:54.36.872] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'async'
                  Require stack:
                  - /home/pi/MagicMirror/modules/MMM-Tools/node_helper.js
                  [12.08.2022 19:54.36.913] [ERROR] App threw an error during load
                  [12.08.2022 19:54.36.926] [ERROR] Error: Cannot find module 'async'
                  Require stack:
                      at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
                      at n._resolveFilename (node:electron/js2c/browser_init:245:1105)
                      at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                      at Module._load (node:internal/modules/cjs/loader:785:27)
                      at c._load (node:electron/js2c/asar_bundle:5:13343)
                      at Module.require (node:internal/modules/cjs/loader:1012:19)
                      at require (node:internal/modules/cjs/helpers:102:18)
                      at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Tools/node_helper.js:6:13)
                      at Module._compile (node:internal/modules/cjs/loader:1118:14)
                      at Module._extensions..js (node:internal/modules/cjs/loader:1173:10)
                  [12.08.2022 19:54.36.929] [ERROR] Whoops! There was an uncaught exception...
                  [12.08.2022 19:54.36.978] [ERROR] Error: Cannot find module 'async'
                  Require stack:
                      at Module._extensions..js (node:internal/modules/cjs/loader:1173:10) {
                    code: 'MODULE_NOT_FOUND',
                    requireStack: [
                      '/home/pi/MagicMirror/modules/MMM-Tools/node_helper.js',
                      '/home/pi/MagicMirror/js/app.js',
                      '/home/pi/MagicMirror/js/electron.js',
                      '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                      undefined
                  [12.08.2022 19:54.36.981] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [12.08.2022 19:54.36.982] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  [1635:0812/195502.091221:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                  [1743:0812/195503.364570:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                  [1769:0812/195503.879521:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                  [12.08.2022 20:06.05.090] [WARN]  You're using a full whitelist configuration to allow for all IPs
                  [1676:0812/200609.075206:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                  [1730:0812/200610.010984:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                  [1749:0812/200610.493257:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                    sdetweil @aunrea
                    @aunrea yep
                    the link I gave u had the instructions in the 1st post
                    find the message, get the name, install it in the module folder
                    there are more than one library file missing. depends on the module… so I have to teach you the process.
                      aunrea @sdetweil
                      @sdetweil I think when I tried to install mmpm that it didn’t install correctly. I did it again and everything seems fine except I still have a black screen. But somehow in the web using the ip address it loads fine. Why would I get a black screen on the pi but everything working on the web? I even made a change to make sure it wasn’t cached and the change showed up so it’s new.
                        aunrea @aunrea
                        I have been getting the following error mm-error.log:
                        [12.08.2022 22:50.16.819] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        [1707:0812/225020.891765:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                        [1749:0812/225021.867756:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                        [1768:0812/225022.360451:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                        /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                        [12.08.2022 23:24.59.722] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        [1686:0812/232504.792579:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                        [1735:0812/232505.286195:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                        [12.08.2022 23:46.19.653] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        [1623:0812/234649.995261:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                        [1766:0812/234650.598873:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
