    Black Screen after installing fonts-noto-color-emoji
    26 Posts 4 Posters 9.8k Views 4 Watching
      aunrea
      Re: 🎂🥂Emoji support
      I tried sudo apt install fonts-noto-color-emoji and it installed fine. After the reboot I now just get a black screen.
      I then tried npm run config:check and I got this message:
      npm ERR! code ENOENT
      npm ERR! syscall open
      npm ERR! errno -2
      npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm ERR! enoent This is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR!     /home/pi/.npm/_logs/2022-08-12T16_15_05_667Z-debug.log
      Here is the error log file:
      0 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'run', 'config:check' ]
      1 info using npm@7.21.0
      2 info using node@v10.23.2
      3 timing npm:load:whichnode Completed in 2ms
      4 timing config:load:defaults Completed in 10ms
      5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 16ms
      6 timing config:load:builtin Completed in 18ms
      7 timing config:load:cli Completed in 12ms
      8 timing config:load:env Completed in 3ms
      9 timing config:load:project Completed in 7ms
      10 timing config:load:file:/home/pi/.npmrc Completed in 3ms
      11 timing config:load:user Completed in 4ms
      12 timing config:load:file:/usr/etc/npmrc Completed in 1ms
      13 timing config:load:global Completed in 2ms
      14 timing config:load:validate Completed in 2ms
      15 timing config:load:credentials Completed in 6ms
      16 timing config:load:setEnvs Completed in 5ms
      17 timing config:load Completed in 70ms
      18 timing npm:load:configload Completed in 72ms
      19 timing npm:load:setTitle Completed in 1ms
      20 timing npm:load:setupLog Completed in 5ms
      21 timing config:load:flatten Completed in 23ms
      22 timing npm:load:cleanupLog Completed in 20ms
      23 timing npm:load:configScope Completed in 0ms
      24 timing npm:load:projectScope Completed in 1ms
      25 timing npm:load Completed in 141ms
      26 timing command:run-script Completed in 41ms
      27 verbose stack Error: ENOENT: no such file or directory, open '/home/pi/package.json'
      28 verbose cwd /home/pi
      29 verbose Linux 5.4.83-v7+
      30 verbose argv "/usr/bin/node" "/usr/bin/npm" "run" "config:check"
      31 verbose node v10.23.2
      32 verbose npm  v7.21.0
      33 error code ENOENT
      34 error syscall open
      35 error path /home/pi/package.json
      36 error errno -2
      37 error enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      38 error enoent This is related to npm not being able to find a file.
      39 verbose exit -2
      It appears I am missing the file package.json, but I don’t know what that is or how to make/get the file.
      kayakbabeK S 2 Replies Last reply Reply Quote 0
        arosenhave @sdetweil
        @sdetweil I am so sorry. I don’t know how I missed this from one installation to another but feel truly ashamed. What happened is that I used a copy of config.js that I thought was the one working from previous install. But it was missing the classes clause to show the modules.
        Again, so sorry and super grateful for putting me on the right track :)
        • kayakbabeK Offline
          kayakbabe @aunrea
          @aunrea
          What is happening is that npm can’t find config:check in /home/pi/
          You have to move into the Magicmirror folder before running
            sdetweil @aunrea
            @aunrea you are in the wrong folder
            A 1 Reply Last reply Reply Quote 1
              aunrea @sdetweil
              Didn’t realize the path mattered.
              > magicmirror@2.20.0 config:check
              > node js/check_config.js
              /home/pi/MagicMirror/node_modules/@eslint/eslintrc/dist/eslintrc.cjs:2383
              const require$1 = Module.createRequire(require('url').pathToFileURL(__filename).toString());
              TypeError: Module.createRequire is not a function
                  at Object.<anonymous> (/home/pi/MagicMirror/node_modules/@eslint/eslintrc/dist/eslintrc.cjs:2383:26)
                  at Module.require (internal/modules/cjs/loader.js:692:17)
                  at require (internal/modules/cjs/helpers.js:25:18)
                  at Object.<anonymous> (/home/pi/MagicMirror/node_modules/eslint/lib/cli-engine/cli-engine.js:33:5)
              I don’t understand this.
              kayakbabeK S 3 Replies Last reply Reply Quote 0
                kayakbabe @aunrea
                @aunrea did you run?
                first switch to the MagicMirror folder like this
                cd /home/pi/MagicMirror/
                then run this command
                  sdetweil @aunrea
                  @aunrea see
                  https://github.com/MichMich/MagicMirror/issues/2772
                  you need to upgrade node and npm to minimum levels
                  use my install script next time
                    sdetweil @aunrea
                    @aunrea said in Black Screen after installing fonts-noto-color-emoji:
                    mm is just an app installed on the system
                      aunrea
                      I have updated npm and node (in MagicMirror directory). I still have a black screen (I have done a reboot). When I run the config check I get a message saying there is no errors.
                      [12.08.2022 15:58.52.189] [INFO]  Checking file...  /home/pi/MagicMirror/config/                                       config.js
                      [12.08.2022 15:58.52.486] [INFO]  Your configuration file doesn't contain syntax                                        errors :)
                        sdetweil @aunrea
                        @aunrea after upgrading, you have to reinstall mm
                        and maybe any modules
                        still black screen maybe this
                        show is the messages at mm start
                        if using pm2 then
                        pm2 --lines=50
                          aunrea @sdetweil
                          I did a clean install of mm, added my modules, copied the saved config from the previous install to the new install. Everything looked fine, then I rebooted and now I again have a black screen!!!
                          The npm log says:
                           verbose cli /usr/bin/node /usr/bin/npm
                          1 info using npm@8.11.0
                          2 info using node@v16.16.0
                          4 timing config:load:defaults Completed in 12ms
                          5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 7ms
                          6 timing config:load:builtin Completed in 9ms
                          7 timing config:load:cli Completed in 9ms
                          9 timing config:load:file:/home/pi/MagicMirror/.npmrc Completed in 0ms
                          10 timing config:load:project Completed in 26ms
                          11 timing config:load:file:/home/pi/.npmrc Completed in 0ms
                          12 timing config:load:user Completed in 3ms
                          13 timing config:load:file:/usr/etc/npmrc Completed in 1ms
                          14 timing config:load:global Completed in 2ms
                          15 timing config:load:validate Completed in 2ms
                          16 timing config:load:credentials Completed in 19ms
                          17 timing config:load:setEnvs Completed in 7ms
                          18 timing config:load Completed in 96ms
                          19 timing npm:load:configload Completed in 97ms
                          20 timing npm:load:mkdirpcache Completed in 5ms
                          21 timing npm:load:mkdirplogs Completed in 5ms
                          22 verbose title npm start
                          23 verbose argv "start"
                          24 timing npm:load:setTitle Completed in 6ms
                          25 timing config:load:flatten Completed in 18ms
                          26 timing npm:load:display Completed in 23ms
                          27 verbose logfile logs-max:10 dir:/home/pi/.npm/_logs
                          28 verbose logfile /home/pi/.npm/_logs/2022-08-13T00_05_23_038Z-debug-0.log
                          29 timing npm:load:logFile Completed in 36ms
                          30 timing npm:load:timers Completed in 1ms
                          31 timing npm:load:configScope Completed in 1ms
                          32 timing npm:load Completed in 182ms
                          33 silly logfile start cleaning logs, removing 1 files
                          34 silly logfile done cleaning log files
                          The pm2 error log says:
                          [8711:0812/191224.893179:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                          [8764:0812/191225.738183:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                          [8716:0812/191225.822559:ERROR:command_buffer_proxy_impl.cc(126)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                          [1644:0812/194324.158131:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                          [1694:0812/194325.043000:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                          [1718:0812/194325.555134:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                          [1672:0812/194325.644795:ERROR:command_buffer_proxy_impl.cc(126)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                          [12.08.2022 19:54.36.872] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'async'
                          Require stack:
                          - /home/pi/MagicMirror/modules/MMM-Tools/node_helper.js
                          [12.08.2022 19:54.36.913] [ERROR] App threw an error during load
                          [12.08.2022 19:54.36.926] [ERROR] Error: Cannot find module 'async'
                          Require stack:
                              at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
                              at n._resolveFilename (node:electron/js2c/browser_init:245:1105)
                              at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                              at Module._load (node:internal/modules/cjs/loader:785:27)
                              at c._load (node:electron/js2c/asar_bundle:5:13343)
                              at Module.require (node:internal/modules/cjs/loader:1012:19)
                              at require (node:internal/modules/cjs/helpers:102:18)
                              at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Tools/node_helper.js:6:13)
                              at Module._compile (node:internal/modules/cjs/loader:1118:14)
                              at Module._extensions..js (node:internal/modules/cjs/loader:1173:10)
                          [12.08.2022 19:54.36.929] [ERROR] Whoops! There was an uncaught exception...
                          [12.08.2022 19:54.36.978] [ERROR] Error: Cannot find module 'async'
                          Require stack:
                              at Module._extensions..js (node:internal/modules/cjs/loader:1173:10) {
                            code: 'MODULE_NOT_FOUND',
                            requireStack: [
                              '/home/pi/MagicMirror/modules/MMM-Tools/node_helper.js',
                              '/home/pi/MagicMirror/js/app.js',
                              '/home/pi/MagicMirror/js/electron.js',
                              '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                              undefined
                          [12.08.2022 19:54.36.981] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                          [12.08.2022 19:54.36.982] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                          [1635:0812/195502.091221:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                          [1743:0812/195503.364570:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                          [1769:0812/195503.879521:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                          [12.08.2022 20:06.05.090] [WARN]  You're using a full whitelist configuration to allow for all IPs
                          [1676:0812/200609.075206:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                          [1730:0812/200610.010984:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                          [1749:0812/200610.493257:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                            sdetweil @aunrea
                            @aunrea yep
                            the link I gave u had the instructions in the 1st post
                            find the message, get the name, install it in the module folder
                            there are more than one library file missing. depends on the module… so I have to teach you the process.
                              aunrea @sdetweil
                              @sdetweil I think when I tried to install mmpm that it didn’t install correctly. I did it again and everything seems fine except I still have a black screen. But somehow in the web using the ip address it loads fine. Why would I get a black screen on the pi but everything working on the web? I even made a change to make sure it wasn’t cached and the change showed up so it’s new.
                                aunrea @aunrea
                                I have been getting the following error mm-error.log:
                                [12.08.2022 22:50.16.819] [WARN]  You're using a full whitelist configuration to allow for all IPs
                                [1707:0812/225020.891765:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                                [1749:0812/225021.867756:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                                [1768:0812/225022.360451:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                                /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                                [12.08.2022 23:24.59.722] [WARN]  You're using a full whitelist configuration to allow for all IPs
                                [1686:0812/232504.792579:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                                [1735:0812/232505.286195:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                                [12.08.2022 23:46.19.653] [WARN]  You're using a full whitelist configuration to allow for all IPs
                                [1623:0812/234649.995261:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                                [1766:0812/234650.598873:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                                  sdetweil @aunrea
                                  @aunrea are you running the 64 bit raspi os?
                                  this is a configuration problem when using the Vulcan video driver.
                                    aunrea @sdetweil
                                    @sdetweil I am running the 32 bit raspi os. I used the official raspberry pi imager to create it.
                                      aunrea @aunrea
                                      I think it’s a GPU issue. Could it have been a bad install of the os? Should I reinstall?
                                        sdetweil @aunrea
                                        @aunrea I do not know
                                          aunrea
                                          Ok I am going to try a new install on my raspberry pi 4, instead of the 3B I have been using.
                                            arosenhave @aunrea
                                            @aunrea any luck resolving this issue?
                                            I have a fresh install of MM on an RPI4 (Rasbian OS 32bit) and get the same problem when installing MMM-Face-Reco-DNN. Only errors I have in the logs are the same GPU related ones.
                                            And the strange thing is that I have the exact same setup on a different SD card done 6 weeks ago. And that works perfectly. It reporst my MM is outdated, but I don’t dare updating it now.
                                              sdetweil @arosenhave
                                              @arosenhave depends on which video driver is enabled in /boot/config.txt
                                              edit the script which starts MM
                                              and add
                                              export ELECTRON_DISABLE_GPU=1
                                              before the
                                              npm start
                                              line
