Unsolved Black Screen "Electron" after updating MM
I do this :
but nothing… -
@RIKKO14 correct… in linux most commands return nothing if successful…
so that is good… you asked to erase a folder
and it did thatnow restart MagicMirror
pm2 start MagicMirror
@sdetweil Nothing has changed
@RIKKO14 fun… try this
we need to edit a js file
cd ~/MagicMirror/js nano electron.js
scroll down to
let address = (config.address === void 0) | (config.address === "") ? (config.address = "localhost") : config.address;
add a bank line after
on the blank line, copy/paste these lines
mainWindow.webContents.on("new-window", function(event, url) { event.preventDefault(); // This will open a new Electron window to load the url. shell.openExternal(url); });
so it looks like this when you are done
let address = (config.address === void 0) | (config.address === "") ? (config.address = "localhost") : config.address; mainWindow.webContents.on("new-window", function(event, url) { event.preventDefault(); // This will open a new Electron window to load the url. shell.openExternal(url); }); mainWindow.loadURL(`${prefix}${address}:${config.port}`);
ctrl-o to save the file
ctrl-x to exit nano
cd …then
pm2 restart MagicMirror
@sdetweil after doing this :
cd ~.MagicMirror/js nano electron.js
I have this :
So I can’t scroll anywhere…
@RIKKO14 sorry typo, try again
I tryed 2 times with space and with not space before
mainWindow.webContents.on (...)
https://zupimages.net/viewer.php?id=22/34/77nw.jpg
but style the same…
@RIKKO14 can’t see the image. u can just upload here, 3 icon from right in editor
tabs don’t matter
@RIKKO14 do u have a real display on pi?
or using vnc all the time?
