    Does not work
    5 Posts 2 Posters 1.1k Views 2 Watching
    • V Offline
      Volkae
      Re: MMM-WunderGround-PWS-Observations
      @Saabman
      After installing your modul, MM does not start. Idea? Here the lines:
      npm run start
      magicmirror@2.20.0 start
      [05.09.2022 14:38.42.387] [LOG] Starting MagicMirror: v2.20.0
      [05.09.2022 14:38.42.404] [LOG] Loading config …
      [05.09.2022 14:38.42.418] [LOG] Loading module helpers …
      [05.09.2022 14:38.42.424] [LOG] No helper found for module: alert.
      [05.09.2022 14:38.42.478] [LOG] Initializing new module helper …
      [05.09.2022 14:38.42.485] [LOG] Module helper loaded: updatenotification
      [05.09.2022 14:38.42.490] [LOG] No helper found for module: clock.
      [05.09.2022 14:38.42.995] [LOG] Initializing new module helper …
      [05.09.2022 14:38.42.997] [LOG] Module helper loaded: calendar
      [05.09.2022 14:38.43.000] [LOG] No helper found for module: compliments.
      [05.09.2022 14:38.43.004] [LOG] No helper found for module: weather.
      [05.09.2022 14:38.43.033] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘request’
      Require stack:
      • /home/pi/MagicMirror/modules/MMM-WunderGround-PWS-Observations/node_helper.js
      [05.09.2022 14:38.43.055] [LOG] Loading module helpers …
      [05.09.2022 14:38.43.060] [LOG] No helper found for module: alert.
      [05.09.2022 14:38.43.062] [LOG] Initializing new module helper …
      [05.09.2022 14:38.43.064] [LOG] Module helper loaded: updatenotification
      [05.09.2022 14:38.43.066] [LOG] No helper found for module: clock.
      [05.09.2022 14:38.43.069] [LOG] Initializing new module helper …
      [05.09.2022 14:38.43.072] [LOG] Module helper loaded: calendar
      [05.09.2022 14:38.43.076] [LOG] No helper found for module: compliments.
      [05.09.2022 14:38.43.079] [LOG] No helper found for module: weather.
      [05.09.2022 14:38.43.087] [ERROR] App threw an error during load
      [05.09.2022 14:38.43.096] [ERROR] Error: Cannot find module ‘request’
      Require stack:
      • at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
        at n._resolveFilename (node:electron/js2c/browser_init:245:1105)
        at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
        at Module._load (node:internal/modules/cjs/loader:785:27)
        at c._load (node:electron/js2c/asar_bundle:5:13343)
        at Module.require (node:internal/modules/cjs/loader:1012:19)
        at require (node:internal/modules/cjs/helpers:102:18)
        at Object. (/home/pi/MagicMirror/modules/MMM-WunderGround-PWS-Observations/node_helper.js:11:15)
        at Module._compile (node:internal/modules/cjs/loader:1118:14)
        at Module._extensions…js (node:internal/modules/cjs/loader:1173:10)
        [05.09.2022 14:38.43.102] [ERROR] Whoops! There was an uncaught exception…
        [05.09.2022 14:38.43.125] [ERROR] Error: Cannot find module ‘request’
        Require stack:
        at Module._extensions…js (node:internal/modules/cjs/loader:1173:10) {
        code: ‘MODULE_NOT_FOUND’,
        requireStack: [
        ‘/home/pi/MagicMirror/modules/MMM-WunderGround-PWS-Observations/node_helper.js’,
        ‘/home/pi/MagicMirror/js/app.js’,
        ‘/home/pi/MagicMirror/js/electron.js’,
        ‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
        undefined
        [05.09.2022 14:38.43.135] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [05.09.2022 14:38.43.137] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        [05.09.2022 14:38.43.734] [LOG] Launching application.
        [2203:0905/143844.762678:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
        [2230:0905/143845.008543:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
        [05.09.2022 14:41.14.673] [LOG] Shutting down server…
        [05.09.2022 14:41.14.680] [LOG] Stopping module helper: updatenotification
        [05.09.2022 14:41.14.682] [LOG] Stopping module helper: calendar
        [05.09.2022 14:41.14.684] [LOG] Stopping module helper: updatenotification
        [05.09.2022 14:41.14.685] [LOG] Stopping module helper: calendar
        [05.09.2022 14:41.14.688] [ERROR] Whoops! There was an uncaught exception…
        [05.09.2022 14:41.14.692] [ERROR] TypeError: Cannot read properties of undefined (reading ‘close’)
        at App.stop (/home/pi/MagicMirror/js/app.js:257:14)
        at App. (/home/pi/MagicMirror/js/electron.js:145:7)
        at App.emit (node:events:526:28)
        at appMethod (node:electron/js2c/browser_init:69:1830)
        at Object.execute (node:electron/js2c/browser_init:69:5966)
        at MenuItem.click (node:electron/js2c/browser_init:73:1862)
        at a._executeCommand (node:electron/js2c/browser_init:81:2453)
        [05.09.2022 14:41.14.695] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [05.09.2022 14:41.14.699] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        pi@raspberrypi:~/MagicMirror/config $
        sdetweil @Volkae
        @Volkae see
        https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later, post 1
        • V Offline
          Volkae @sdetweil
          Thank you for your support but it´s still not running. I did all the steps you listed but there is still black screen.
          Here the lines:
          [06.09.2022 14:20.07.952] [LOG] Starting MagicMirror: v2.20.0
          [06.09.2022 14:20.07.968] [LOG] Loading config …
          [06.09.2022 14:20.07.993] [LOG] Loading module helpers …
          [06.09.2022 14:20.07.999] [LOG] No helper found for module: alert.
          [06.09.2022 14:20.08.063] [LOG] Initializing new module helper …
          [06.09.2022 14:20.08.070] [LOG] Module helper loaded: updatenotification
          [06.09.2022 14:20.08.077] [LOG] No helper found for module: clock.
          [06.09.2022 14:20.08.637] [LOG] Initializing new module helper …
          [06.09.2022 14:20.08.639] [LOG] Module helper loaded: calendar
          [06.09.2022 14:20.08.651] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘request’
          Require stack:
          [06.09.2022 14:20.08.654] [LOG] Loading module helpers …
          [06.09.2022 14:20.08.656] [LOG] No helper found for module: alert.
          [06.09.2022 14:20.08.671] [LOG] Initializing new module helper …
          [06.09.2022 14:20.08.674] [LOG] Module helper loaded: updatenotification
          [06.09.2022 14:20.08.676] [LOG] No helper found for module: clock.
          [06.09.2022 14:20.08.678] [LOG] Initializing new module helper …
          [06.09.2022 14:20.08.680] [LOG] Module helper loaded: calendar
          [06.09.2022 14:20.08.688] [ERROR] App threw an error during load
          [06.09.2022 14:20.08.695] [ERROR] Error: Cannot find module ‘request’
          Require stack:
            [06.09.2022 14:20.08.700] [ERROR] Whoops! There was an uncaught exception…
            [06.09.2022 14:20.08.720] [ERROR] Error: Cannot find module ‘request’
            Require stack:
            requireStack: [
            undefined
            [06.09.2022 14:20.08.730] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [06.09.2022 14:20.08.731] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            [06.09.2022 14:20.09.319] [LOG] Launching application.
            [3525:0906/142010.469551:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
            [3555:0906/142010.766784:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
            [06.09.2022 14:20.24.644] [LOG] Shutting down server…
            [06.09.2022 14:20.24.650] [LOG] Stopping module helper: updatenotification
            [06.09.2022 14:20.24.652] [LOG] Stopping module helper: calendar
            [06.09.2022 14:20.24.653] [LOG] Stopping module helper: updatenotification
            [06.09.2022 14:20.24.655] [LOG] Stopping module helper: calendar
            [06.09.2022 14:20.24.657] [ERROR] Whoops! There was an uncaught exception…
            [06.09.2022 14:20.24.661] [ERROR] TypeError: Cannot read properties of undefined (reading ‘close’)
            [06.09.2022 14:20.24.664] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [06.09.2022 14:20.24.666] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            pi@raspberrypi:~/MagicMirror $
            sdetweil @Volkae
            @Volkae said in Does not work:
            hm… maybe not?
            • V Offline
              Volkae @sdetweil
              I did the same procedure again, now it works!!
              Thanks a lot!!!
