    ES6 notation
    7 Posts 3 Posters 2.0k Views 3 Watching
    • mumblebajM
      mumblebaj Module Developer
      I have a “stupid” question. Is ES6 notation possible with MM? i.e. import fetch from 'node-fetch';
      I tried this before and I got errors.
      SyntaxError: Cannot use import statement outside a module
          at Object.compileFunction (node:vm:352:18)
          at wrapSafe (node:internal/modules/cjs/loader:1039:15)
          at Module._compile (node:internal/modules/cjs/loader:1074:27)
          at Module._extensions..js (node:internal/modules/cjs/loader:1173:10)
          at Module.load (node:internal/modules/cjs/loader:988:32)
          at Module._load (node:internal/modules/cjs/loader:829:12)
          at c._load (node:electron/js2c/asar_bundle:5:13343)
          at Module.require (node:internal/modules/cjs/loader:1012:19)
          at require (node:internal/modules/cjs/helpers:102:18)
          at loadModule (/home/mumble/MagicMirror/js/app.js:127:19)
      [07.09.2022 19:15.59.646] [ERROR] Whoops! There was an uncaught exception...
      Declaration from node_helper,js
      //const fetch = require('node-fetch')
      const moment = require("moment")
      const querystring = require("querystring")
      If it is possible, how is it done?
      S M 3 Replies Last reply
        sdetweil @mumblebaj
        @mumblebaj i don’t think its available in MM
        by default the filetype mjs can use import
        BUT mm does require(‘node_helper.js’)
        js/app.js
                        const helperPath = `${moduleFolder}/node_helper.js`;
                                const Module = require(helperPath);
        mumblebajM 1 Reply Last reply
        • mumblebajM
          @sdetweil Thanks Sam. Is there any plan that it would one day be possible? Certain helper modules, newer versions that is, only supports ES6 notation. If we don’t move along with the times then we may get stuck in the “dark ages” so to say.
          Older versions have security vulnerabilities etc.
            MMRIZE @mumblebaj
            @mumblebaj
            You can use “import()”, but need some tricks.
            • wait enough time to finish importing
            • or use promise to confirm loading finishes.
            I used that trick in my MMM-Scenes module to import modular mjs instead of global injections.
              sdetweil @mumblebaj
              @mumblebaj i am not in the loop on the plans for future MM designs, details…
              best to open an issue and ask Mich
                MMRIZE @mumblebaj
                @mumblebaj
                Ref this; https://forum.magicmirror.builders/topic/15761/best-practice-for-import-esm-in-mm-module?_=1662569185624
                It was for front mm module, but you can apply in the node_helper also. (Easier, because you don’t need to wait dom creation to inject script in node_helper, just do finish importing confirmation before first work begins in your start() method, or at least before using that module.)
                • mumblebajM
                  mumblebaj Module Developer @MMRIZE
                  @MMRIZE and @sdetweil Thanks guys, Thought I would put the question out there and see what crawls out the woodwork. ;-)
