    GPIO'S
    7 Posts 3 Posters 1.7k Views 3 Watching
      Anthony Project Sponsor @BKeyport
      @BKeyport Thank you for your reply. what do you mean bu saying that the problem is timing? I already have made a topic in rasberry forum and waiting for reply.
      • BKeyportB Offline
        BKeyport Module Developer @Anthony
        @Anthony Smart LEDs are highly reliant on data timing being exact.
          @BKeyport said in GPIO'S:
          The problem is that except GPIO22 which working all other GPIOs I checked never worked. Even if the command show it works. Well if I do not get a valid answer from rasberry forum to fix it I won’t use the status leds. I can leave with that :smiling_face_with_sunglasses:
          • kayakbabeK Offline
            kayakbabe
            @BKeyport You’ll be limited by the amperage of the Raspberry Pi power supply. You might be able to power about 3 feet of an led strip. But for anything longer, you will need more amperage. Look on Adafruit for “light painting” with a raspberry pi. They discuss the power needs of the strips. Also the more modules you have runnning, the more power the pi will use itself. SO… you might not even be able to power 3 feet.
              Anthony Project Sponsor @kayakbabe
              @kayakbabe My problem was not the power because I power the led strip from external power supply. I figured out that somehow the GPIOs I wanted was not set as output mode and high state. I set them and everything is working fine. Thank you for your reply.
