    Having trouble with launch- perhaps display value?
    11 Posts 3 Posters 6.5k Views 3 Watching
      jayd272
      I updated a really old install, and now I am getting the following message. Any ideas on how to solve?
      pi@raspberrypi:~/MagicMirror $ npm run start
      > magicmirror@2.20.0 start
      [14.09.2022 22:02.09.148] [LOG]   Starting MagicMirror: v2.20.0
      [14.09.2022 22:02.09.161] [LOG]   Loading config ...
      [14.09.2022 22:02.09.172] [LOG]   Loading module helpers ...
      [14.09.2022 22:02.09.782] [LOG]   Initializing new module helper ...
      [14.09.2022 22:02.09.784] [LOG]   Module helper loaded: MMM-HASS
      [14.09.2022 22:02.10.266] [LOG]   Initializing new module helper ...
      [14.09.2022 22:02.10.268] [LOG]   Module helper loaded: MMM-Wallpaper
      [14.09.2022 22:02.10.271] [LOG]   No helper found for module: clock.
      [14.09.2022 22:02.10.602] [LOG]   Initializing new module helper ...
      [14.09.2022 22:02.10.604] [LOG]   Module helper loaded: calendar
      [14.09.2022 22:02.10.608] [LOG]   Initializing new module helper ...
      [14.09.2022 22:02.10.610] [LOG]   Module helper loaded: MMM-TautulliActivity
      [14.09.2022 22:02.10.611] [LOG]   No helper found for module: weather.
      [14.09.2022 22:02.10.647] [LOG]   Initializing new module helper ...
      [14.09.2022 22:02.10.648] [LOG]   Module helper loaded: newsfeed
      [14.09.2022 22:02.10.649] [LOG]   All module helpers loaded.
      [14.09.2022 22:02.10.811] [LOG]   Starting server on port 8080 ...
      [14.09.2022 22:02.10.835] [LOG]   Server started ...
      [14.09.2022 22:02.10.837] [LOG]   Connecting socket for: MMM-HASS
      [14.09.2022 22:02.10.839] [LOG]   Connecting socket for: MMM-Wallpaper
      [14.09.2022 22:02.10.840] [LOG]   Starting node helper for: MMM-Wallpaper
      [14.09.2022 22:02.10.841] [LOG]   Connecting socket for: calendar
      [14.09.2022 22:02.10.842] [LOG]   Starting node helper for: calendar
      [14.09.2022 22:02.10.844] [LOG]   Connecting socket for: MMM-TautulliActivity
      [14.09.2022 22:02.10.845] [LOG]   Starting module helper: MMM-TautulliActivity
      [14.09.2022 22:02.10.846] [LOG]   Connecting socket for: newsfeed
      [14.09.2022 22:02.10.847] [LOG]   Starting node helper for: newsfeed
      [14.09.2022 22:02.10.849] [LOG]   Sockets connected & modules started ...
      [1716:0914/220210.856927:ERROR:ozone_platform_x11.cc(247)] Missing X server or $DISPLAY
      [1716:0914/220210.857140:ERROR:env.cc(226)] The platform failed to initialize.  Exiting.
      /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
        sdetweil @jayd272
        @jayd272 is your system running in console mode?
        must be full desktop mode
          Remco
          I got the same issue after updating .
          ==> MagicMirror-error.log <==
          [24318:1012/112446.727714:ERROR:env.cc(226)] The platform failed to initialize. Exiting.
          [24496:1012/112454.856543:ERROR:ozone_platform_x11.cc(247)] Missing X server or $DISPLAY
          [24496:1012/112454.856766:ERROR:env.cc(226)] The platform failed to initialize. Exiting.
          [24565:1012/112510.603377:ERROR:ozone_platform_x11.cc(247)] Missing X server or $DISPLAY
          [24565:1012/112510.603597:ERROR:env.cc(226)] The platform failed to initialize. Exiting.
          [24624:1012/112526.200613:ERROR:ozone_platform_x11.cc(247)] Missing X server or $DISPLAY
          [24624:1012/112526.200835:ERROR:env.cc(226)] The platform failed to initialize. Exiting.
          Did you find a solution?
            sdetweil @Remco
            @Remco can u show the beginning output of npm start…
            first 5 or 6 lines
              Remco
              $ npm start
              magicmirror@2.21.0 start
              [12.10.2022 13:36.16.036] [LOG] Starting MagicMirror: v2.21.0
              [12.10.2022 13:36.16.052] [LOG] Loading config …
              [12.10.2022 13:36.16.068] [LOG] Loading module helpers …
              [12.10.2022 13:36.16.074] [LOG] No helper found for module: alert.
              [12.10.2022 13:36.16.114] [LOG] Initializing new module helper …
              [12.10.2022 13:36.16.116] [LOG] Module helper loaded: updatenotification
              [12.10.2022 13:36.16.119] [LOG] No helper found for module: clock.
              [12.10.2022 13:36.16.660] [LOG] Initializing new module helper …
              [12.10.2022 13:36.16.665] [LOG] Module helper loaded: calendar
              [12.10.2022 13:36.16.669] [LOG] No helper found for module: compliments.
              [12.10.2022 13:36.16.671] [LOG] No helper found for module: weather.
              [12.10.2022 13:36.16.720] [LOG] Initializing new module helper …
              [12.10.2022 13:36.16.721] [LOG] Module helper loaded: newsfeed
              [12.10.2022 13:36.16.723] [LOG] All module helpers loaded.
              [12.10.2022 13:36.16.973] [LOG] Starting server on port 8080 …
              [12.10.2022 13:36.17.004] [LOG] Server started …
              [12.10.2022 13:36.17.006] [LOG] Connecting socket for: updatenotification
              [12.10.2022 13:36.17.008] [LOG] Starting module helper: updatenotification
              [12.10.2022 13:36.17.010] [LOG] Connecting socket for: calendar
              [12.10.2022 13:36.17.012] [LOG] Starting node helper for: calendar
              [12.10.2022 13:36.17.014] [LOG] Connecting socket for: newsfeed
              [12.10.2022 13:36.17.018] [LOG] Starting node helper for: newsfeed
              [12.10.2022 13:36.17.019] [LOG] Sockets connected & modules started …
              [24680:1012/133617.027945:ERROR:ozone_platform_x11.cc(247)] Missing X server or $DISPLAY
              [24680:1012/133617.028297:ERROR:env.cc(226)] The platform failed to initialize. Exiting.
                sdetweil @Remco
                @Remco ok, some more diagnostics commands
                node -v
                npm -v
                lsb_release -a
                uname -a
                ps -ef | grep -i x11
                how did u upgrade? manual or my script?
                if my script can u send me the installers/upgrade.log
                use my userid at gmail. ( file is too big to post here)
                note that you must be running the graphical desktop for MM full mode to execute …
                server only mode without desktop is ok
                npm run server
                then u would access from some other system
                  Remco
                  I have done a manual update of MM and pi when the problems started.
                  I have also tried to run your installation script but the problem is still there. I have also tried to update node.js and npm to the latest versions.
                  These are requested outputs:
                  $ node -v
                  v18.10.0
                  $ npm -v
                  8.19.2
                  $ lsb_release -a
                  No LSB modules are available.
                  Distributor ID: Raspbian
                  Description: Raspbian GNU/Linux 10 (buster)
                  Release: 10
                  Codename: buster
                  $ uname -a
                  Linux raspberrypi 5.15.56-v7+ #1575 SMP Fri Jul 22 20:28:11 BST 2022 armv7l GNU/Linux
                  $ ps -ef | grep -i x11
                  pi 27931 5155 0 22:18 pts/0 00:00:00 grep --color=auto -i x11
                    @Remco said in Having trouble with launch- perhaps display value?:
                    ok, try this
                    ps -ef  | grep Xorg
                    is this a server machine?, or does it have a display? where MM is shown?
                      Remco
                      MM is running on a Pi with it’s own screen.
                      But in the meantime I got it working again. I found this threat with had similar errors as I had when running ‘startx’.
                      After I removed this driver MM started again:
                      sudo mv /usr/share/X11/xorg.conf.d/99-fbturbo.conf ~
                      startx
                      But I do still have the following errors in the error-log:
                      [16183:1013/103255.149031:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                      [16220:1013/103256.721936:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                      [16188:1013/103256.801401:ERROR:command_buffer_proxy_impl.cc(126)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                        sdetweil @Remco
                        @Remco for the gpu errors do
                        add
                        export ELECTRON_DISABLE_GPU=1
                        in the script that starts mm
                        just before the npm start line
                          sdetweil @Remco
                          @Remco also, if u ran my upgrade script, can u send me the ~/MagicMirror/installers/upgrade.log file
                          • C chris_d referenced this topic on
