    Having trouble with launch- perhaps display value?
    11 Posts 3 Posters 6.0k Views 3 Watching
      sdetweil @Remco
      @Remco can u show the beginning output of npm start…
      first 5 or 6 lines
        Remco
        $ npm start
        magicmirror@2.21.0 start
        [12.10.2022 13:36.16.036] [LOG] Starting MagicMirror: v2.21.0
        [12.10.2022 13:36.16.052] [LOG] Loading config …
        [12.10.2022 13:36.16.068] [LOG] Loading module helpers …
        [12.10.2022 13:36.16.074] [LOG] No helper found for module: alert.
        [12.10.2022 13:36.16.114] [LOG] Initializing new module helper …
        [12.10.2022 13:36.16.116] [LOG] Module helper loaded: updatenotification
        [12.10.2022 13:36.16.119] [LOG] No helper found for module: clock.
        [12.10.2022 13:36.16.660] [LOG] Initializing new module helper …
        [12.10.2022 13:36.16.665] [LOG] Module helper loaded: calendar
        [12.10.2022 13:36.16.669] [LOG] No helper found for module: compliments.
        [12.10.2022 13:36.16.671] [LOG] No helper found for module: weather.
        [12.10.2022 13:36.16.720] [LOG] Initializing new module helper …
        [12.10.2022 13:36.16.721] [LOG] Module helper loaded: newsfeed
        [12.10.2022 13:36.16.723] [LOG] All module helpers loaded.
        [12.10.2022 13:36.16.973] [LOG] Starting server on port 8080 …
        [12.10.2022 13:36.17.004] [LOG] Server started …
        [12.10.2022 13:36.17.006] [LOG] Connecting socket for: updatenotification
        [12.10.2022 13:36.17.008] [LOG] Starting module helper: updatenotification
        [12.10.2022 13:36.17.010] [LOG] Connecting socket for: calendar
        [12.10.2022 13:36.17.012] [LOG] Starting node helper for: calendar
        [12.10.2022 13:36.17.014] [LOG] Connecting socket for: newsfeed
        [12.10.2022 13:36.17.018] [LOG] Starting node helper for: newsfeed
        [12.10.2022 13:36.17.019] [LOG] Sockets connected & modules started …
        [24680:1012/133617.027945:ERROR:ozone_platform_x11.cc(247)] Missing X server or $DISPLAY
        [24680:1012/133617.028297:ERROR:env.cc(226)] The platform failed to initialize. Exiting.
        /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
          sdetweil @Remco
          @Remco ok, some more diagnostics commands
          node -v
          npm -v
          lsb_release -a
          uname -a
          ps -ef | grep -i x11
          how did u upgrade? manual or my script?
          if my script can u send me the installers/upgrade.log
          use my userid at gmail. ( file is too big to post here)
          note that you must be running the graphical desktop for MM full mode to execute …
          server only mode without desktop is ok
          npm run server
          then u would access from some other system
            Remco
            I have done a manual update of MM and pi when the problems started.
            I have also tried to run your installation script but the problem is still there. I have also tried to update node.js and npm to the latest versions.
            These are requested outputs:
            $ node -v
            v18.10.0
            $ npm -v
            8.19.2
            $ lsb_release -a
            No LSB modules are available.
            Distributor ID: Raspbian
            Description: Raspbian GNU/Linux 10 (buster)
            Release: 10
            Codename: buster
            $ uname -a
            Linux raspberrypi 5.15.56-v7+ #1575 SMP Fri Jul 22 20:28:11 BST 2022 armv7l GNU/Linux
            $ ps -ef | grep -i x11
            pi 27931 5155 0 22:18 pts/0 00:00:00 grep --color=auto -i x11
              @Remco said in Having trouble with launch- perhaps display value?:
              ok, try this
              ps -ef  | grep Xorg
              is this a server machine?, or does it have a display? where MM is shown?
                Remco
                MM is running on a Pi with it’s own screen.
                But in the meantime I got it working again. I found this threat with had similar errors as I had when running ‘startx’.
                After I removed this driver MM started again:
                sudo mv /usr/share/X11/xorg.conf.d/99-fbturbo.conf ~
                startx
                But I do still have the following errors in the error-log:
                [16183:1013/103255.149031:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                [16220:1013/103256.721936:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                [16188:1013/103256.801401:ERROR:command_buffer_proxy_impl.cc(126)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                  sdetweil @Remco
                  @Remco for the gpu errors do
                  add
                  export ELECTRON_DISABLE_GPU=1
                  in the script that starts mm
                  just before the npm start line
                    sdetweil @Remco
                    @Remco also, if u ran my upgrade script, can u send me the ~/MagicMirror/installers/upgrade.log file
                    • C chris_d referenced this topic on
