    Rasberry Replacement
    9 Posts 4 Posters 2.9k Views 4 Watching
      Anthony Project Sponsor @sdetweil
      @sdetweil I start building it at June. So it is only 4 months old. You think it will be just fine with the old SD and the OS it is already installed on it? If so it will be savior for me. I want to avoid all modules reinstall and especialy creating new project on google for Google Assistant.
        sdetweil @Anthony
        @Anthony yes, the OS is current
          sdetweil @Anthony
          @Anthony don’t have to create new Google project, just use the credentials file u already have
          backup, backup, backup
          use my script. saves custom.css, config.js and the url of all installed modules
          https://github.com/sdetweil/MagicMirror-backup-restore
          saves and can push that to gjthub
          and restore from there and resetup all the modules…
            @sdetweil Then you are a savior too. Thank you so much. I will do it ASAP.
              Anthony Project Sponsor @Anthony
              UPDATE!
              Hello everyone. I would like to tell you that I just migrate from Rasberry pi 3B+ to Rasberry pi 4B 4GB. I just want to tell you that It worked perfectly by just instering the SD from the old pi. The only thing I had to do Is to configure the audio output bacause I use hdmi to transfer audio. Everything else worked as a charm. OS, MM, GA, leds everything. I made this update in case someone else is thinking if it is possible. Well IT IS!!!
                rubelahamed
                UPDATE!
