    save some information from a xml or json to a txt file
    25 Posts 5 Posters 22.3k Views 5 Watching
      Squirrel @LukeCodewalker
      @LukeCodewalker i want to make the same Module for Switzerland but i don`t know how to find the json data for my region…
      Can you help me please? ;) I found your link in the node_helper.js file. From where do you got that?
      I would like o work with http://alarm.meteocentrale.ch/
      L 2 Replies Last reply
      • L
        LukeCodewalker Module Developer @Squirrel
        @Squirrel
        i did some reverse engineering of the dwd-website and found this json file.
        i had a short look at your link and did not found something similar there. do you know if theres an app for ios where the data is shown? maybe i can help you then.
        • L
          @Squirrel
          maybe this link helps you:
          https://s3-eu-central-1.amazonaws.com/app-prod-static-fra.meteoswiss-app.ch/v1/warnings_with_outlook_with_naturalhazards_de.json
            Squirrel
            @LukeCodewalker Thx for the answer. I will try it out. At the moment i can`t find my City. But maybe only because there is no warning at the moment? Otherwise on the alarm.meteocentrale.ch is still a warning for snow on the streets…?
            What about wetteralarm.ch/? This is a app for iPhone and Android! Maybe it can work with this site?
            L 1 Reply Last reply
            • L
              @Squirrel
              I can’t download this app in germany, so I can’t have a look at the data it uses.
                Squirrel
                Ok. Shit happens. Maybe you can tell me with which program/method u read the code of a app? The I can do it alone…
                • L
                  @Squirrel
                  I use mitmproxy for viewing the http-requests of the apps.
                    Squirrel
                    Thx! After some little problems to install all the things to use mitmproxy it works now and i found some good json files. The only problem i have is that there is one json for region where i can`t choose a city. There are different json files for every city! Maybe i gonna make a module with regions for everybody but use the city json for my self!
                      Squirrel
                      Hmm since i changed some things in node_helper.js my MagicMirror is no more working and i get the following ERROR:
                      npm ERR! Linux 4.4.34-v7+
                      npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
                      npm ERR! node v0.12.6
                      npm ERR! npm v2.11.2
                      npm ERR! code ELIFECYCLE
                      npm ERR! magicmirror@2.0.0 start: electron js/electron.js
                      npm ERR! Exit status 1
                      npm ERR!
                      npm ERR! Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
                      npm ERR! This is most likely a problem with the magicmirror package,
                      npm ERR! not with npm itself.
                      npm ERR! electron js/electron.js
                      npm ERR! You can get their info via:
                      npm ERR! npm owner ls magicmirror
                      npm ERR! /home/pi/MagicMirror/npm-debug.log
                      This is what i did in config.js:
                      module: 'MMM-DWD-WarnWeather',
                      position: 'bottom_right',
                      header: 'Wetterwarnungen',
                          region: 'Seeland/Bielersee',					// Kreis Lörrach
                          changeColor: true,
                          interval: 10 * 60 * 1000, // every 10 minutes
                          loadingText: 'Warnungen werden geladen...',
                          noWarningText: 'Keine Warnungen'
                      And here what i did in node_helper.js :
                      getWarningData: function (region) {
                      	var self = this;
                      	var timestamp = Date.now().toString();
                      	var url = 'http://my.wetter.ch/v6/alarms/meteo/with-regions.json' + timestamp;			// http://www.dwd.de/DWD/warnungen/warnapp_landkreise/json/warnings.json?jsonp=loadWarnings
                      	request({
                      		url: url,
                      		method: 'GET'
                      	}, function (error, response, body) {
                      		var result = JSON.parse(body.substr(24).slice(0, -2));
                      		var warningData = [];
                      		for (var regionId in result['warnings']) {
                      			if (result['warnings'][regionId][0]['name_de'] == region) {			// name_de = regionName
                      				var warnings = [];
                      				for (var warning in result['warnings'][regionId]) {
                      					warnings.push(result['warnings'][regionId][warning]);
                      				if (warnings.length > 0) {
                      					warningData = warnings;
                      		self.sendSocketNotification('WARNINGS_DATA', {warnings: warningData, region: region});
                      I changed the link and i changed regionName to name_de… Any idea? Hope this is gonna be my last Question ;)
                      • L
                        @Squirrel
                        So first of all i would suggest you to open a new topic in the development area of this forum.
                        Second, it looks like you have not much experience http-requests and data-structures =D but that’s no problem =) it’s a good point to start for you now =)
                        To help you i need the request which you have monitored with mitmproxy.
                        To do that, open the request in mitmproxy and press E to export it. Then choose curl command as output-format and choose a file where you save this command.
                        With this command i can explain you how to go on. So please post the content of this file in the new topic which you will create now =)
                        • morozgrafixM
                          morozgrafix Moderator @gismo2006
                          @gismo2006 I know this thread is solved and a few months old. There is also another one liner solution with use of jq JSON parser from command line. Here is an example that would get result that you need (or at least get you close to it)
                          curl -s "http://api.openweathermap.org/data/2.5/weather?id=2934486&lang=de&units=metric&mode=json&appid=YOUR_OWM_API_KEY" | jq -r '"Today is " + .weather[].description + " and " + (.main["temp"]|tostring) + " degrees."' > filename.txt
                          would result in Today is überwiegend bewölkt and -6.12 degrees. put into filename.txt
