    save some information from a xml or json to a txt file
    25 Posts 5 Posters 22.2k Views 5 Watching
    • L
      LukeCodewalker Module Developer @Squirrel
      @Squirrel
      I use mitmproxy for viewing the http-requests of the apps.
        Squirrel
        Thx! After some little problems to install all the things to use mitmproxy it works now and i found some good json files. The only problem i have is that there is one json for region where i can`t choose a city. There are different json files for every city! Maybe i gonna make a module with regions for everybody but use the city json for my self!
          Squirrel
          Hmm since i changed some things in node_helper.js my MagicMirror is no more working and i get the following ERROR:
          npm ERR! Linux 4.4.34-v7+
          npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
          npm ERR! node v0.12.6
          npm ERR! npm v2.11.2
          npm ERR! code ELIFECYCLE
          npm ERR! magicmirror@2.0.0 start: electron js/electron.js
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
          npm ERR! This is most likely a problem with the magicmirror package,
          npm ERR! not with npm itself.
          npm ERR! electron js/electron.js
          npm ERR! You can get their info via:
          npm ERR! npm owner ls magicmirror
          npm ERR! /home/pi/MagicMirror/npm-debug.log
          This is what i did in config.js:
          module: 'MMM-DWD-WarnWeather',
          position: 'bottom_right',
          header: 'Wetterwarnungen',
              region: 'Seeland/Bielersee',					// Kreis Lörrach
              changeColor: true,
              interval: 10 * 60 * 1000, // every 10 minutes
              loadingText: 'Warnungen werden geladen...',
              noWarningText: 'Keine Warnungen'
          And here what i did in node_helper.js :
          getWarningData: function (region) {
          	var self = this;
          	var timestamp = Date.now().toString();
          	var url = 'http://my.wetter.ch/v6/alarms/meteo/with-regions.json' + timestamp;			// http://www.dwd.de/DWD/warnungen/warnapp_landkreise/json/warnings.json?jsonp=loadWarnings
          	request({
          		url: url,
          		method: 'GET'
          	}, function (error, response, body) {
          		var result = JSON.parse(body.substr(24).slice(0, -2));
          		var warningData = [];
          		for (var regionId in result['warnings']) {
          			if (result['warnings'][regionId][0]['name_de'] == region) {			// name_de = regionName
          				var warnings = [];
          				for (var warning in result['warnings'][regionId]) {
          					warnings.push(result['warnings'][regionId][warning]);
          				if (warnings.length > 0) {
          					warningData = warnings;
          		self.sendSocketNotification('WARNINGS_DATA', {warnings: warningData, region: region});
          I changed the link and i changed regionName to name_de… Any idea? Hope this is gonna be my last Question ;)
          • L
            @Squirrel
            So first of all i would suggest you to open a new topic in the development area of this forum.
            Second, it looks like you have not much experience http-requests and data-structures =D but that’s no problem =) it’s a good point to start for you now =)
            To help you i need the request which you have monitored with mitmproxy.
            To do that, open the request in mitmproxy and press E to export it. Then choose curl command as output-format and choose a file where you save this command.
            With this command i can explain you how to go on. So please post the content of this file in the new topic which you will create now =)
            • morozgrafixM
              morozgrafix Moderator @gismo2006
              @gismo2006 I know this thread is solved and a few months old. There is also another one liner solution with use of jq JSON parser from command line. Here is an example that would get result that you need (or at least get you close to it)
              curl -s "http://api.openweathermap.org/data/2.5/weather?id=2934486&lang=de&units=metric&mode=json&appid=YOUR_OWM_API_KEY" | jq -r '"Today is " + .weather[].description + " and " + (.main["temp"]|tostring) + " degrees."' > filename.txt
              would result in Today is überwiegend bewölkt and -6.12 degrees. put into filename.txt
