Solved MMM-Carousel (global)
@sdetweil Sam, i cnat´believe it…i put this in the config too:
position: 'bottom_bar', // Required to draw in position
and now it´s going :-) yeahhhh thanks a lot Sam !!!
so then looks like my MM-Carousel now and it´s going:
{ module: 'MMM-Carousel', position: 'bottom_bar', // Required to draw in position config: { transitionInterval: 10000, showPageIndicators: true, showPageControls: true, ignoreModules: ['clock', 'alert', 'MMM-SoccerLiveScore', 'MMM-OpenmapWeather', 'weather', 'MMM-Traffic', 'calendar', 'MMM-ioBroker', 'MMM-Fuel'], mode: 'global' } },
@kusselin I do not have position set in mine.
glad it’s working
@sdetweil yes that is funny, but you see now it goes…the console is/was also o.k. or?
Thank you sam for your help an fast answers!! TOP!!
EDIT: One question: MMM-Tankerkönig is out of the modules…right?
@kusselin I don’t see that you excluded it…
@kusselin what version of magicmirror are you running?
grep version ~/MagicMirror/package.json
@sdetweil v2.21.0
@kusselin said in MMM-Carousel (global):
what do you mean by not excluded?
The MMM-Carousel is running now…
I still had the module “Snow” installed…
Does that have to be entered in the IngnoreListe around that it runs again?
@kusselin excluded from carousel
u did not put it in the ignoreList
