    MMM-Carousel (global)
    25 Posts 2 Posters 9.7k Views 2 Watching
    • kusselinK Offline
      kusselin @sdetweil
      @sdetweil o.k. thanks for your answer…
      what do you mean about “other module came and went”?
      you mean your other modules you have installed right?
      i musst look about a keyboard…then i will be back here again with the errors
      • kusselinK Offline
        kusselin
        look, this coming…i had made photos…can you see anything sdetweil?
        this is all what is red
        MMM-Carousel is in my config standing at last…is this ok?
          sdetweil @kusselin
          @kusselin came and went,
          means appeared and disappeared, some change every 10 seconds. have 15 modules installed(testing modules for other user problems)
          shows weather for 10 seconds
          then
          shows, GooglePhotos , for 10 seconds
          then
          shows MMM-OpenmapWeather, for 10 seconds
          etc
          each in their configured position: setting
          kusselinK 1 Reply Last reply Reply Quote 0
          • kusselinK Offline
            kusselin @sdetweil
            @sdetweil Sam, i cnat´believe it…i put this in the config too:
            position: 'bottom_bar',  // Required to draw in position
            and now it´s going :-) yeahhhh thanks a lot Sam !!!
            so then looks like my MM-Carousel now and it´s going:
                        module: 'MMM-Carousel',
                            transitionInterval: 10000,
            				showPageIndicators: true,
                            showPageControls: true,
                            ignoreModules: ['clock', 'alert', 'MMM-SoccerLiveScore', 'MMM-OpenmapWeather', 'weather', 'MMM-Traffic', 'calendar', 'MMM-ioBroker', 'MMM-Fuel'],
                            mode: 'global'
              sdetweil @kusselin
              @kusselin I do not have position set in mine.
              glad it’s working
              • kusselinK Offline
                kusselin @sdetweil
                @sdetweil yes that is funny, but you see now it goes…the console is/was also o.k. or?
                • kusselinK Offline
                  kusselin
                  Thank you sam for your help an fast answers!! TOP!!
                  EDIT: One question: MMM-Tankerkönig is out of the modules…right?
                    sdetweil @kusselin
                    @kusselin I don’t see that you excluded it…
                      sdetweil @kusselin
                      @kusselin what version of magicmirror are you running?
                      grep version ~/MagicMirror/package.json
                      • kusselinK Offline
                        kusselin @sdetweil
                        @sdetweil v2.21.0
                        • kusselinK Offline
                          kusselin @kusselin
                          @kusselin said in MMM-Carousel (global):
                          what do you mean by not excluded?
                          • kusselinK Offline
                            kusselin
                            The MMM-Carousel is running now…
                            I still had the module “Snow” installed…
                            Does that have to be entered in the IngnoreListe around that it runs again?
                              sdetweil @kusselin
                              @kusselin excluded from carousel
                              u did not put it in the ignoreList
                                sdetweil @kusselin
                                @kusselin Snow. I do not know individual modules.
                                all carousel is doing is showing or hiding modules
                                • kusselinK Offline
                                  kusselin @sdetweil
                                  @sdetweil no sam it is not included in the ignore list and yet it does not work now…
                                  CTRL+Shift +i again ?
                                    sdetweil @kusselin
                                    @kusselin possibly
                                    snow just takes a long time to get started displaying…
                                    and each time its selected to display it starts over…
                                    it was designed to be on the screen all the time…
                                    it works on my system… need interval to be 20000 or more
                                    • kusselinK Offline
                                      kusselin @sdetweil
                                      @sdetweil o.k. i put the snow module in ignore list…now ist going :-)
                                        sdetweil @kusselin
                                        @kusselin cool…
