    MMM-Remote-Control actually
    7 Posts 3 Posters 1.4k Views 3 Watching
    • kusselinK Offline
      kusselin @sdetweil
      @sdetweil but iam in my own network at home…so i can get this 127.0.0.1
      Or is this wrong?
      • kusselinK Offline
        kusselin
        You are so great sdetweil :-)
        so ist running:
        config = {
        	address: "0.0.0.0", 	// Address to listen on, can be:
        	port: 8080,
        	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
        	ipWhitelist: [], 	// Set [] to allow all IP addresses
        thanks a lot again to you
          sdetweil @kusselin
          @kusselin no… localhost means ONLY INSIDE the same machine… (127.0.0.1 is the ip address for localhost)
          phone on wifi accessing MM on pi is a different machine
          the default protection is a mirror hanging on the wall, no one would need to access that from outside the mirror…
          oops remote -control does need
          • BKeyportB Offline
            BKeyport Module Developer @kusselin
            @kusselin FYI, Jopyth is the original author.
            kusselinK 1 Reply Last reply Reply Quote 0
            • kusselinK Offline
              kusselin @BKeyport
              @BKeyport thanks…
