    Black screen when starting MM...
    6 Posts 2 Posters 1.9k Views 2 Watching
    • T Offline
      Turtle
      Hello all,
      So, it’s been a while since I’ve worked on MM. So, I just recently upgraded my PI3 and updated MM as well to the latest version. I’m getting a black screen whenever I’m starting MM. This is what I’m getting after running /npm start…(any help is appreciated)
      >magicmirror@2.21.0 start /home/pi/MagicMirror
      [17.10.2022 05:48.57.151] [LOG]   Starting MagicMirror: v2.21.0
      [17.10.2022 05:48.57.182] [LOG]   Loading config ...
      [17.10.2022 05:48.57.218] [LOG]   Loading module helpers ...
      [17.10.2022 05:48.57.231] [LOG]   No helper found for module: alert.
      [17.10.2022 05:48.57.307] [LOG]   Initializing new module helper ...
      [17.10.2022 05:48.57.312] [LOG]   Module helper loaded: updatenotification
      [17.10.2022 05:48.57.319] [LOG]   No helper found for module: clock.
      [17.10.2022 05:48.57.350] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'valid-url'
      Require stack:
      - /home/pi/MagicMirror/modules/MMM-CalendarExt2/node_helper.js
      [17.10.2022 05:48.57.356] [LOG]   Loading module helpers ...
      [17.10.2022 05:48.57.362] [LOG]   No helper found for module: alert.
      [17.10.2022 05:48.57.367] [LOG]   Initializing new module helper ...
      [17.10.2022 05:48.57.370] [LOG]   Module helper loaded: updatenotification
      [17.10.2022 05:48.57.374] [LOG]   No helper found for module: clock.
      [17.10.2022 05:48.57.398] [ERROR] App threw an error during load
      [17.10.2022 05:48.57.406] [ERROR] Error: Cannot find module 'valid-url'
      Require stack:
          at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
          at n._resolveFilename (node:electron/js2c/browser_init:245:1105)
          at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Module._load (node:internal/modules/cjs/loader:785:27)
          at c._load (node:electron/js2c/asar_bundle:5:13343)
          at Module.require (node:internal/modules/cjs/loader:1012:19)
          at require (node:internal/modules/cjs/helpers:102:18)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-CalendarExt2/node_helper.js:3:18)
          at Module._compile (node:internal/modules/cjs/loader:1118:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1173:10)
      [17.10.2022 05:48.57.413] [ERROR] Whoops! There was an uncaught exception...
      [17.10.2022 05:48.57.445] [ERROR] Error: Cannot find module 'valid-url'
      Require stack:
          at Module._extensions..js (node:internal/modules/cjs/loader:1173:10) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/home/pi/MagicMirror/modules/MMM-CalendarExt2/node_helper.js',
          '/home/pi/MagicMirror/js/app.js',
          '/home/pi/MagicMirror/js/electron.js',
          '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
          undefined
      [17.10.2022 05:48.57.458] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [17.10.2022 05:48.57.460] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [17.10.2022 05:48.58.962] [LOG]   Launching application.
      [1049:1017/054900.709871:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      [1076:1017/054901.244060:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
      Turtle
        sdetweil @Turtle
        @Turtle see
        • T Offline
          Turtle @sdetweil
          @sdetweil - thank you for the help. It’s finally working with your help. My calendar is up and running. But another quick question, I’m using npm start to start the calendar. How would I stop the calendar? Again, Thank you!
          Turtle
            sdetweil @Turtle
            @Turtle ctrl-c will stop the MM instance
            • T Offline
              Turtle @sdetweil
              @sdetweil - well, that explains it…I was using ctrl-r and wondering why it wasn’t working. Eventually, I was just “x” out of the terminal window. Again, thank you for the help.
              Turtle
                sdetweil @Turtle
                @Turtle while looking at the MM screen
                ctrl-r will reload
                ctrl-q will quit
                ctrl-m will minimize
                all same as on Windows for full screen apps
