    Animation Transition on MMM-Slideshow
    11 Posts 2 Posters 3.4k Views 2 Watching
    • O Offline
      Ouaoua
      I would like to code something based on this module to add a transition animation (like appearing and disappearing with a set time).
      Being a clear noob on coding, Could someone help me?
      Here’s the link to the base module and my Issue : https://github.com/AdamMoses-GitHub/MMM-ImageSlideshow/issues/31#issue-1419373932
      I tried to copy some lines from the MMM-Imagesphoto modules but can’t seem to make it work
      Thanks to anyone seeing this
        sdetweil @Ouaoua
        @Ouaoua I am not sure what animation with set time means.
        the images already transition in some timed cycle
        • O Offline
          Ouaoua @sdetweil
          @sdetweil Something like a fade in / fade out (like those transition on Powerpoint :D)
            sdetweil @Ouaoua
            @Ouaoua ok, that would be css transitions
            you can add those to the class used for the images without writing any JavaScript code
            • O Offline
              Ouaoua @sdetweil
              @sdetweil So I just have to add in the module js file
              Transition: width 2s;
              Or do I have to add something in the css file?
                sdetweil @Ouaoua
                @Ouaoua you would add css settings to
                ~/MagicMirror/css/custom.css
                (if it doesn’t exist, create it
                touch ~/MagicMirror/css/custom.css
                then it would be
                .modulename .class { (// like .MMM-Slideshow
                and whatever css operations are to be applied to that class
                see
                https://stackoverflow.com/questions/11660710/css-transition-fade-in
                the MM css design is a stack
                custom.css at the top
                module .css in the middle
                main.css at the bottom
                the layout searchs custom 1st, then module then main
                1st found wins
                here is a post about how to use the browser dev window to locate content classes and styles and temporarliy mod them to get the effect , and learn what u need to put in custom.css
                https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1666112800952
                  this showed up in my news feed
                  https://developer.mozilla.org/en-US/docs/Web/CSS/CSS_Transitions/Using_CSS_transitions
                  • O Offline
                    Ouaoua @sdetweil
                    @sdetweil Thanks a lot for your help!!! <3
                    • O Offline
                      Ouaoua @sdetweil
                      @sdetweil Ok So I wrote the code in the custom.css file as you said but in the website you sent me it is written that I need to add a line in the js file of the module too.
                      The line:
                      <h1 class="fade-in">Fade Me Down Scotty</h1>
                      Obviously I need to change “Fade Me Down Scotty”
                      I tried to add it myself but can’t make it work as I don’t know where to put this in the js file of the module.
                      Could you help me one last time?
                      Thanks a lot :D
                        sdetweil @Ouaoua
                        @Ouaoua
                        so the css starts
                        .MMM-SlideShow .fade-in {
                        … whatever
                        now you need to replace fade-in w the class u find on the image already created by the module
                        if no unique cllass, the u can select the image tag element
                        .MMM-SlideShow img {
                        …whatever
