    Dynamic change in the size and position of modules
    11 Posts 4 Posters 3.3k Views 4 Watching
      Azazlo
      I’m looking for a module with which you can change the position and size of modules dynamically. The MMM-ModulePosition has a very similar functionality, but there you need to restart the mirror and rewrite the css file. I also want me to save the new location and size of the modules and the mirror continues to work, does such a module exist at the moment?
        sdetweil @Azazlo
        @Azazlo maybe (from 3rd party list)
        https://github.com/Toreke/MMM-Dynamic-Modules.git
          Azazlo @sdetweil
          I saw this module, but honestly I could not figure out how it works.
          I don’t really understand where to insert the line “this.sendNotification(CHANGE_POSITIONS_DEFAULTS);” from this module
            sdetweil @Azazlo
            @Azazlo some other app (mmm-remotecontrol maybe) has to send it a message to move module x to position y
            here are the available positions
            https://docs.magicmirror.builders/modules/configuration.html
            A 2 Replies Last reply Reply Quote 0
              Azazlo @sdetweil
              That’s the point. I need to be able to modify directly with the mouse on the screen, as in the module that I gave as an example. It is very convenient and looks nice, but it does not have a save function without restarting and overwriting the file
                Azazlo @sdetweil
                  sdetweil @Azazlo
                  @Azazlo ok, you didn’t say that… no module provides drag/drop positioning of other modules
                  maybe you can merge them together
                    Azazlo @sdetweil
                    :_(
                    MMM-ModulePosition almost perfect, except for the impossibility of making changes without restarting and rewriting the file. Although I would put up with the fact that you need to restart the program, if only it was automatic
                    • T Offline
                      TheBodger
                      In case anyone comes by here, please let me know what improvements can be made to the MMM-ModulePosition tool, and I will see if i can incorporate them into it. TheBodger
                      • L Offline
                        lucifer6669 @TheBodger
                        @TheBodger I am actually using your module, and it was working great until the the most recent update and now there is only one module i can move around the others wont let me. any suggestions would be helpful thank you
